Error transferring internal Bitmap using BitBlt
Hein Gustavsen
Hi
We get the following error message (message box) using Delphi XE built-in TeeChart:
Error transferring internal Bitmap using BitBlt (C:\Builds\TpAddons\TeeChart\TeCanvas.pas, line 6316)
The same code runs fine with Delphi 2007. We do not have the source code for that TeeChart version so I don't know what causes the failure. Is this a bug and is there a known work-around?
Hein Gustavsen
Hein Gustavsen
Re: Error transferring internal Bitmap using BitBlt
Hi Hein,
Can you please attach a simple example project we can run "as-is" to reproduce the problem and debug it here?
Hein Gustavsen
I really don't have any suitable example projects, but the error has appeared in at least three different applications and in both Windows XP and Windows 7 64-bit environments. The error only appears a few times a week and is not related to user input (zoom/pan) or adding data to the chart. We use time stamps as X values and a few thousand samples (2000+) using one serie. The following DFM output is directly from a project where the error happens regularly:
It would help us if we could prevent the error message from appearing.
Hein Gustavsen
object Chart1: TChart
Left = 8
Top = 8
Width = 944
Height = 405
Legend.Visible = False
Title.Text.Strings = (
'TChart')
Title.Visible = False
View3D = False
TabOrder = 0
ColorPaletteIndex = 13
object Series1: TFastLineSeries
Marks.Arrow.Visible = True
Marks.Callout.Brush.Color = clBlack
Marks.Callout.Arrow.Visible = True
Marks.Visible = False
LinePen.Color = 10708548
XValues.DateTime = True
XValues.Name = 'X'
XValues.Order = loAscending
YValues.Name = 'Y'
YValues.Order = loNone
end
endRegards,
Hein Gustavsen
Hi Hein,
I'm not able to reproduce the problem here using the code you posted. Delphi XE includes TeeChart Std v9 (aka v2010). While Delphi 2007 includes TeeChart Std v7. Which TeeChart version are you using in Delphi 2007? It would be very helpful if you could try to arrange a simple example project we can run "as-is" to reproduce the problem and debug it here. Also, you may want to try using latest TeeChart 2010 VCL maintenance release available at the client area for both registered and evaluation version users.
Hein Gustavsen
Hi
I was able to reproduce the problem with the attached source code. It did not watch it continuously, but it took no more than 30 minutes before the error appeared. The test was run on a Windows XP computer. We have now confirmed the problem on four computers (XP and Win7 x64).
I hope you are able to reproduce the problem now.
Hein Gustavsen
Hein Gustavsen
Hein Gustavsen
This QC report may affect this bug. Is is fixed in Delphi XE Update 1.
http://qc.embarcadero.com/wc/qcmain.aspx?d=88382
I don't know if this applies to the TeeChart DCUs, but I have not been able to reproduce the error after installing Update 1. I am not using debug DCUs.
Hein Gustavsen
Hein Gustavsen
Hein Gustavsen
We used the included TeeChart Std v7 and TeeChart Pro v8 in Delphi 2007.Narcís wrote:Delphi XE includes TeeChart Std v9 (aka v2010). While Delphi 2007 includes TeeChart Std v7. Which TeeChart version are you using in Delphi 2007?
Hein Gustavsen
Hi Hein,
Thanks for your feedback. As far as I know nothing changed in TeeChart for update 1 so it must be an Embarcadero thing but Quality Central doesn't mark the issue as fixed yet. Anyway, I couldn't reproduce the issue here either running your project with Delphi XE + Update 1 with default TeeChart v9 Std for about 45 minutes nor running it in Delphi 7 with TeeChart v9 Pro for about 30 minutes. If you find a consistent way to reproduce the issue again don't hesitate to let us know.
Hein Gustavsen
I think QC 88382 is fixed since it is in the list of fixed bugs in Delphi and C++ Builder XE Update 1:
http://edn.embarcadero.com/de/article/40984/
If Embarcadero compiles TeeChart DCUs for their releases, then this issue should also affect TeeChart. Anyway, if assertions are turned off, the error is only hidden, and not fixed. You may want to look at the specific code line where the assertion happens to make sure it is not a serious error. I know I will do the same when we get the V9 source code.
Thanks for your help.
Hein Gustavsen
Hein Gustavsen
Hi Hein,
Ok, thanks. They haven't updated this 88382 status in QC thenI think QC 88382 is fixed since it is in the list of fixed bugs in Delphi and C++ Builder XE Update 1:
Yes, probably but what Embarcadero includes in their products is beyond our control.If Embarcadero compiles TeeChart DCUs for their releases, then this issue should also affect TeeChart.
Yes, the problem is that TeCanvas.pas is one of the core units of TeeChart. Therefore it's in constant evolution and I'm not sure which will be current line corresponding to line number 6316 in the version shipped with Delphi XE. We should be able to reproduce this debugging the sources. Anyway, I installed our current v9 sources in Delphi XE, compiled the application with debugging assertions enabled and ran the test for around 40 minutes with no error.Anyway, if assertions are turned off, the error is only hidden, and not fixed. You may want to look at the specific code line where the assertion happens to make sure it is not a serious error. I know I will do the same when we get the V9 source code.
If you can reproduce the issue don't hesitate to let us know.I know I will do the same when we get the V9 source code.
Hein Gustavsen
My test application has run for two days without any error. I am pretty sure the problem is solved with RAD Studio XE Update 1.
Hein Gustavsen
Hein Gustavsen
Hi Hein,
Thank you very much for your feedback. I'm glad to hear the problem has been solved at your end.
WilliEbert
we have this problem, too. But we are using Delphi 2010 with TeeChartPro 2010 and therefore ther is no patch from Embacadero).
And the code snippet that is shown as source of the error is in line 6464 of TeCanvas,pas (bolt):
Procedure TTeeCanvas3D.TransferBitmap(ALeft,ATop:Integer; ACanvas:TCanvas);
{$IFOPT C+}
var tmpRes : LongBool;
{$ENDIF}
{$IFNDEF CLX}
{$IFDEF MONITOR_REPAINTS}
Inc(TeeMonitor);
FBitmap.Canvas.TextOut(0,0,IntToStr(TeeMonitor));
{$ENDIF}
// Assert(FBitmap.PixelFormat=pfDevice,'Buffer Bitmap PixelFormat <> pfDevice');
{$IFOPT C+}
tmpRes:=
{$ENDIF}
BitBlt( ACanvas.Handle,ALeft,ATop,
FBitmap.Width,
FBitmap.Height,
FBitmap.Canvas.Handle,0,0,SRCCOPY);
{$IFOPT C+}
Assert(tmpRes,'Error transferring internal Bitmap using BitBlt');
{$ENDIF}
{$ELSE}
QPainter_drawPixmap(ACanvas.Handle, ALeft, ATop, FBitmap.Handle, 0, 0,
FBitmap.Width, FBitmap.Height);
{$ENDIF}
It could be that the error is dependent if we work with windows remote desktop or not. The error happens only if we use remote desktop and TeeCahrt is visible but the client remote desktop with the running TeeChart is iconic, the error is not happening if the TeeChart is not visible.
Can you help us?
Your sincerely
Willi
{$IFOPT C+}
{$ENDIF}
{$IFNDEF CLX}
Inc(TeeMonitor);
{$ENDIF}
{$IFOPT C+}
tmpRes:=
{$ENDIF}
FBitmap.Width,
FBitmap.Height,
{$IFOPT C+}
{$ENDIF}
{$ELSE}
{$ENDIF}
Can you help us?
Your sincerely
Willi
Hi Willi,
Are you using latest TeeChart Pro 2010 maintenance release available at the client area, which is v2010.01.11004? Do you have an example project with which we can reproduce the problem here or does it occur using Hein Gustavsen's example at your end?
Hi Willi,
After further testing I could finally reproduce the issue here using Remote Desktop and Hein Gustavsen's example. I have added the issue (TV52015296) to the defect list and will continue investigating it. I will get back to this thread if I find anything relevant.
