Problem with GetLengendPos
Calou
Post by Calou » Tue Dec 07, 2010 4:17 pm
I use this code in order to place a radiogroup
procedure TfrmMain.ChrtOccStatusGetLegendPos(Sender: TCustomChart;  Index: Integer; var X, Y, XColor: Integer);
var
  i:integer;
  chrt:TChart;
  chrt:=Sender as TChart;
  for i := 0 to High(frmOccStatus.TabRdGrpOccStatus) do
    if frmOccStatus.TabRdGrpOccStatus[i].Parent=chrt then
      frmOccStatus.TabRdGrpOccStatus[i].Top:=chrt.Legend.Top+chrt.Legend.Height+10;
      frmOccStatus.TabRdGrpOccStatus[i].Left:=chrt.Legend.Left;
On the chart there are a lot of square by using this event :http://www.cijoint.fr/cjlink.php?file=c ... 7CI34s.jpg
Thanks for help
Re: Problem with GetLengendPos
Post by Narcís » Fri Dec 10, 2010 9:56 am
Hi Calou,
Can you please attach a simple example project we can run "as-is" to reproduce the problem here?
