TeeChart 8 and Delphi XE...
bookman
Post by bookman » Wed Mar 09, 2011 2:06 am
Delphi has been sitting idle for a while due a job change, but I'm now getting things fired up again.
I'm using Delphi XE. My last TeeChartPro is version 8. I have the sourcecode.
Will I be able to get TeeChart 8 to compile and run under XE? I know it's not "supported", but will it work?
Or is there a good reason to not even try? (I'd upgrade, but can't afford it right now).
Re: TeeChart 8 and Delphi XE...
Post by Yeray » Wed Mar 09, 2011 3:04 pm
Hi bookman,
You could try to make it work. Actually, I think TeeRecompile tool included with TeeChart v8 sources supports RAD XE. The first step would be to create the according packages (DclTee815.dpk, DclTee815.res, DclTeePro815.dpk, DclTeePro815.res, Tee815.dpk, Tee815.res, TeeDB815.dpk, TeeDB815.res, TeeGL815.dpk, TeeGL815.res, TeeImage815.dpk, TeeImage815.res, TeeLanguage815.dpk, TeeLanguage815.res, TeePro815.dpk, TeePro815.res, TeeUI815.dpk, TeeUI815.res, TeeWorld815.dpk, TeeWorld815.res).
Tee8Beta
Post by Tee8Beta » Wed Mar 09, 2011 4:09 pm
and also the codes has to be changed to avoid messages like:
TeeProcs.pas(1107) Warning: W1000 Symbol 'ShortTimeFormat' is deprecated: 'Use FormatSettings.ShortTimeFormat'
avnalobin
Post by avnalobin » Thu Mar 31, 2011 3:28 am
is anybody move teechart 8 (with source) to studio xe?
all my components support studio xe, only teechart not :(
Post by Narcís » Thu Mar 31, 2011 7:18 am
Hi avnalobin,
TeeChart VCL does support Delphi, C++ Builder and RAD Studio XE. It is not version 8 which does it but version 2010 does. When RAD Studio XE was released the current TeeChart version at that moment already was 2010 so that was the one to include support for it. TeeChart v8 VCL can be upgraded to 2010 version at http://www.steema.com/order/vcl-pro/u.
