Labels on Radarchart
Broesel
Post by Broesel » Thu Aug 19, 2004 4:29 pm
Hi
Using Radarchart, I like to display lables (the ones I
can put on in the dialog series->format->labels.
If I use one series in chart, its working. But if I make
two clones of this series, the labels are only displayed
if all series are visibled, even if they have all the same
settings.
Thanks for help
Marjan
Post by Marjan » Mon Aug 23, 2004 4:46 pm
Hi.
If you have multiple radar series then only first series labels will be show on the radar chart (mainly to prevent axis label overlapping). If you have multiple radar seris with different number of points, then the obvious workaround for this limitation is to populate first (fake) series with all points and use this series only for displaying axis labels. This can be done by the following code:
fakeSeries.Pen.Visible := False;
fakeSeries.Pointer.Visible := False;
fakeSeries.ShowInLegend := False;
// add all points to first (fake) series
// next, populate other series with individual data
Marjan Slatinek,
