I discovered 2 bugs (going from version 7.12 to 2011.03.30407) that are demonstrated in the attachment:
1) Click a line and see what .Clicked() returns. Version 7.12 counts from 0 and version 2011 counts from 1.
2) In version 7.12 the fonts are rendered with ClearType, in version 2011 they are not.
Bert
2 bugs: Series.Clicked() & font rendering
- TeeChartClicked.rar
- (1.24 KiB) Downloaded 595 times
Re: 2 bugs: Series.Clicked() & font rendering
Another weird thing you may notice here that if you don't explicitly set the color to clRed it will get another color at runtime.
Hello Bert,
I've added it to the wish list to be investigated for future releases (TV52015540).
In the meanwhile you can workaround this adding the TeCanvas unit t the uses clause and setting the TeeFontAntiAlias as follows:
Yes, I see in v2010.01 it still worked as you want, taking the index of the left point. And I see from v2010.02 it takes the index of the right point.Bert B. wrote:1) Click a line and see what .Clicked() returns. Version 7.12 counts from 0 and version 2011 counts from 1.
I think this is relative to an existing item in the wish list (TV52015253).Bert B. wrote:2) In version 7.12 the fonts are rendered with ClearType, in version 2011 they are not.
TeeFontAntiAlias:=DEFAULT_QUALITY;
This is by design. We changed the default color palette to be used in new series to the OperaPalette.Bert B. wrote:Another weird thing you may notice here that if you don't explicitly set the color to clRed it will get another color at runtime.
Thanks for your answers.
I have modified my code and applied the workaround.
Hello Bert,
Regarding to the clicked problem [TV52015540]. We've just fixed it in the sources.
If you are source code customer, you can apply the fix yourself in the Series.pas. See bellow a portion of the ClickedPoint function (nested function in TCustomSeries.Clicked function):
Chang the last line on it to have the following:
if (Index>=tmpFirst) and ClickableLine then
if CheckPointInLine or (FDrawArea and PointInArea(Index)) then
if GetHorizAxis.Inverted then
result:=Succ(Index)
result:=Index;
result:=Succ(Index)
result:=Pred(Index);
This design change causes problems in Delphi 2010 (and maybe other versions). Take the example program and set the color of the LineSerie to clRed.Yeray wrote:This is by design. We changed the default color palette to be used in new series to the OperaPalette.Bert B. wrote: Another weird thing you may notice here that if you don't explicitly set the color to clRed it will get another color at runtime.
Now switch the form to text view (Alt+F12) and notice that SeriesColor is set to clRed. Switch back to form view.
At this time the property is lost although the lineserie is still shown in red. (You can confirm this by switching to text view again.) When you run the application the lineserie is blue again.
The color clRed is still regarded as the default color and does not get stored in the DFM.
Bert
Hello Bert,
It is a know problem for us(TV52015546), how we have explained in this post. I recommend you to be aware at the following channels for new release announcements and what's implemented on them:
- Support forum.
- RSS news feed
- Twitter
- Facebook
- Support forum.
- RSS news feed
