Missing events in TColorLineTool
Lenfors
Post by Lenfors » Mon Jul 11, 2011 9:20 pm
Hello!
I'm missing the events OnMouseEnter and OnMouseLeave for the TColorLineTool.
When I right click on a TColorLineTool I want my popupmenu to activate the feature "Delete ColourLine".
Is there some other way to do this without the above events?
Regards, Mikael
Re: Missing events in TColorLineTool
Post by Yeray » Tue Jul 12, 2011 10:37 am
You could use Chart's OnMouseDown event in combination with the tool Clicked function to check if the TColorLine has been clicked. For example:
var i: Integer;
  for i:=0 to Chart1.Tools.Count-1 do
    if (Chart1.Tools[i] is TColorLineTool) then
      if (Chart1.Tools[i] as TColorLineTool).Clicked(X,Y) then
        Chart1.Tools.Remove(Chart1.Tools[i]);
        Chart1.Repaint;
