View3dOptions.ZoomText not available anymore
Brace
Post by Brace » Mon Aug 01, 2011 12:19 pm
After installing TeeChart 2011 on opening one form I see that this property Chart.View3dOptions.ZoomText is not available.
Could you explain me what exactly has been removed and what is affected?
Brace
Re: View3dOptions.ZoomText not available anymore
Post by Brace » Mon Aug 01, 2011 12:53 pm
I found this in the release notes:
1) ZoomText property is now an enumerated type
(TCanvasZoomText) instead of a boolean.
Chart1.View3DOptions.ZoomText:=ztManual
but the help then says:
TView3DOptions.ZoomText
TView3DOptions
property ZoomText: Boolean;
Unit
TeCanvas
Description
Default = True
ZoomText enables/disables the zooming of text when using the TView3DOptions.Zoom property.
So if I was using FALSE, should I use now NO or MANUAL???
Post by Yeray » Wed Aug 03, 2011 7:48 am
Hello Brace,
With TeeChart v2010.02, the property ZoomText changed from boolean to TCanvasZoomText=(ztManual, ztNo, ztAuto). If I'm not wrong:
- ztManual makes the FontZoom to be applied.
- ztAuto makes the general Zoom to be applied to the texts too.
- ztNo makes the texts not to have any zoom at all, despite of the Zoom or FontZoom values.
We will try to correct the help files asap. Excuse us for the confusion generated.
Brace
Post by Brace » Wed Aug 03, 2011 8:57 am
Ok yes it is clear now. Thanks.
