ChartPreview
Gerben
ChartPreview
Post by Gerben » Mon Sep 06, 2004 6:15 pm
I upgraded from TeeChartProv5 to v6. The only compile error in my old v5 code so far is with ChartPreview.
I like to run the following code:
uses TeeEdiGene;
With Chart1 do
PrintProportional:=False;
PrintMargins:=Rect(5,5,5,5);
PrintResolution:=-50;
PrintOrientation(poLandscape);
ChartPreview(Main_form,Chart1);
My questions:
1) The uses clause was TeePrevi, and still is according to the tutorial. But then ChartPreview is unknown.
2) PrintOrientation(poLandscape); is also copy/pasted from the tutorial, but poLandscape is unknown. I actually want to use poPortrait. TeeProcs is in my uses list. How to solve this ?
Thanks for your help !
Gerben
Marjan
Post by Marjan » Tue Sep 07, 2004 5:59 am
Hi.
ChartPreview routine is declared and implemented in TeeEdiGene unit. The following code, tested with Delphi 6 and TeeChart 6.01, works just fine:
Uses TeeEdiGene, Printers;
  With Chart1 do
  ChartPreview(self,Chart1);
To solve this problem, add the Printers unit to the Uses section.
Marjan Slatinek,
Gerben
Post by Gerben » Tue Sep 07, 2004 2:44 pm
Hi Marjan,
Thanks for the answer, I checked it in Delphi-5 and it worked fine. However it did not completely satisfie my wish.
I have created a chart that definitely has to be printed in portrait mode. Is it possible to bring up ChartPreview with the portrait checkbox checked. Until now landscape is always checked.
I am using Delphi-5 with TeeChart Pro v6.01.
Regards, Gerben
Post by Pep » Tue Sep 07, 2004 10:50 pm
Hi Gerbern,
yes, you can use :
Printer.Orientation := poPortrait;
