but on the build server, I have 2011.04.41118 installed and the footer values overwrite each other:
It's the exact same code, just different version of TChart.
Is there a fix for this?
Ed Dressel
//Problem #1
uses Series;
var i: Integer;
Chart1.View3D:=false;
Chart1.AddSeries(TFastLineSeries);
for i:=0 to 49 do
Chart1[0].AddXY(i, random, IntToStr(Chart1[0].Count));
if i mod 5 = 0 then
Chart1[1].AddXY(i+0.2, random, IntToStr(Chart1[1].Count));
end;Code: Select all
//Problem #2
uses Series;
Chart1[0].AddXY(1, 2, 'test1');
Chart1[0].AddXY(2, 3, 'test2');
Chart1[1].AddXY(0, 2, 'test0');
Chart1[1].AddXY(1, 3, 'test3');
end;![]() | Yeray Alonso Development & Support Steema Software Av. Montilivi 33, 17003 Girona, Catalonia (SP) |
for s:=0 to ISeriesList.Count-1 do![]() | Yeray Alonso Development & Support Steema Software Av. Montilivi 33, 17003 Girona, Catalonia (SP) |
How does a bug, such as this, rank where the X axis is non-readable?Yeray wrote:Usually not. Only if we find a bug is enough critical to justify it we can prepare new installers.
For me to modify your source would mean I would have to get an understanding of your source--I really don't have time for that. I would much prefer showing me which unit(s) and method(s) need to be modified and how.Yeray wrote:But being source code customer, the explanation of the modification above should be enough, isn't it? We can also send the affected files if the customer interested has the sources.
I've added it as "Serious" so its priority in quite high in the list but the time until we can fix it also depends on other variables such as the complexity of the problem, the study of the possible collateral damages, the number of issues with even higher priority that claims our team attention,...TestAlways wrote:How does a bug, such as this, rank where the X axis is non-readable?
Excuse me if my previous reply wasn't detailed enough.TestAlways wrote:For me to modify your source would mean I would have to get an understanding of your source--I really don't have time for that. I would much prefer showing me which unit(s) and method(s) need to be modified and how.
