TPolarSeries
MikeC
TPolarSeries
Post by MikeC » Thu Sep 16, 2004 6:12 pm
Does anyone have an algorithm to plot a circle about a non centered point using a TPolarSeries?
Marjan
Post by Marjan » Fri Sep 17, 2004 2:34 pm
Hi.
All you have to do is transform values from local coordinate system to global angle,radius. The following code should explain what I meant:
// angles measured in radians
procedure TransformCoord(const r0,a0: double; var angle, radius: double);
var x,y: double;
  x := r0*cos(a0) + radius*cos(angle);
  y := r0*cos(a0) + radius*sin(angle);
  radius := Sqrt(Sqr(x)+Sqr(y));
  angle := ArcTan2(y,x);
var t: Integer;
    r,a: Double;
  Series1.GetVertAxis.SetMinMax(0,200);
  Series1.XValues.Order := loNone;
  // draw circle with radius 25 at r0=100, angle = 2*Pi/3
  for t:= 1 to 20 do
    // local coordinates
    r := 25;
    a := 2*Pi*t/20.0;
    // transform to global coords
    TransformCoord(100,2*Pi/3.0,a,r);
    // angle to degrees
    a := a* 180.0/Pi;
    Series1.AddPolar(a,r);
Alternatively, if you only want to draw circle, not related to series points at specific coordinates, all you have to do is manually draw using TChart.Canvas.Circle method in TChart OnAfterDraw event.
Marjan Slatinek,
