Compile error...
Chris_V
Compile error...
Post by Chris_V » Thu Sep 30, 2004 2:07 am
Hi.
I am changing some code written for us way back in 1999, and when I try and compile the applicaiton now I get the following error
"Unit QrTee was compiled with a different version of QuickRpt.TQRPrintable"
I searched google and came up with a site that said to download teechart v4 standard for quick report version 3.
Now I am running teechart v5 pro and delphi 5 and dont know if this is going to mess up my current config of teechart.
can anyone please tell me how I can resolve this issue? I think the initial application was written in Delphi2 but I am not certain, and I dont knw which teechart version was used.
Cheers
Chris Veale
Post by Pep » Thu Sep 30, 2004 6:29 am
Hi Chris,
most likely you've installed a newer QuickReport version and this project was done before install it. In that case you should recompile/reinstall TQRChart component. As you are TeeChart Pro customer then all necessary files + instructions how to do it are usually located in one of TeeChart subfolders (QuickReport). See the 'install.txt' file.
