Kylix2 + Chart.dcu
idontknow
Kylix2 + Chart.dcu
Post by idontknow » Fri Oct 01, 2004 2:10 pm
I want to compile one simple application (unit) using the component Chart.
But the compiler sends the following error:
Fatal: File not found: 'Chart.dcu'
I verified that the Chart.dcu dont exist.
The TChart im using is Teechart5.
Post by Pep » Mon Oct 04, 2004 6:54 am
I think you should set the library path to teechart directory and enable the build with runtime packages option. One customer posted a solution for this "problem" on our newsgroup (the teechart5.kylix newsgroup).
You can see it through the newsgroup search at :
http://www.tamaracka.com/search.htm searching for : chart dcu kylix^teechart*
