Bad headers in series exported to Excel format - TeeChart502
Juri
Post by Juri » Mon Oct 11, 2004 8:33 am
I have got insufficient column headers when exporting
series data to Excel format.
My computer software configuration is:
- MS Windows 2000 5.00.2195 Service Pack 4
- Borland Delphi Enterprise 6.0 (Build 6.240) Update Pack 2
- TeeChart Pro 5.02
1. I have test program with following code:
unit Unit1;
interface
uses
Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
Dialogs, Menus, TeEngine, Series, ExtCtrls, TeeProcs, Chart, TeeEdit;
type
TForm1 = class(TForm)
Chart1: TChart;
Series1: TLineSeries;
Series2: TLineSeries;
Series3: TLineSeries;
MainMenu1: TMainMenu;
miChartEditor: TMenuItem;
ChartEditor1: TChartEditor;
procedure miChartEditorClick(Sender: TObject);
private
{ Private declarations }
public
{ Public declarations }
var
Form1: TForm1;
implementation
{$R *.dfm}
procedure TForm1.miChartEditorClick(Sender: TObject);
with ChartEditor1 do begin
Chart := self.Chart1; Execute;
var
i: integer;
with Chart1 do
for i := 0 to SeriesCount-1 do begin
Series.Title := Chr( Ord('A')+Ord(i) );
Series.FillSampleValues(3);
end.
2. The results of series data export to XML format are:
<?xml version="1.0" ?>
<chart>
<series title="A" type="Line">
<points count="3">
<point Y="570"/>
<point Y="497"/>
<point Y="508"/>
</points>
</series>
<series title="B" type="Line">
<points count="3">
<point Y="545"/>
<point Y="538"/>
<point Y="545"/>
</points>
</series>
<series title="C" type="Line">
<points count="3">
<point Y="518"/>
<point Y="517"/>
<point Y="524"/>
</points>
</series>
</chart>
3. The results of series data export to Excel format and when
exported from Excel to text format are:
Y Y Y
570 545 518
497 538 517
508 545 524
So all column headers are "Y".
What can I do to solve this problem?
Post by Pep » Mon Oct 11, 2004 9:58 am
the export code gets it's column names from series XValues.Name ,YValues.Name and some global variables like TeeMsg_Text. In your case, the following code will do what you need:
Uses TeeConst, TeeStore;
  Series1.Clear;
  Series1.Add(10,'1st');
  Series1.Add(3,'2nd');
  Series1.Add(6,'3rd');
  Series1.YValues.Name := 'CustomBarName';
  TeeMsg_Text := 'CustomTextName';
  with TSeriesDataXLS.Create(Chart1,nil) do
  try
    IncludeHeader := True;
    IncludeLabels := True;
    SaveToFile('d:\temp\test.xls');
  finally
    Free;
Juri
Export to Excel from Chart Editor
Post by Juri » Mon Oct 11, 2004 10:40 am
Hi, Pep. Thank You for quick replay.
You example work fine, but unfortunately I need to use for export only standart properties of Chart Editor. I have full source code of my TeeChart version. Can You give me instructions to rebuild it (if I will find and correct this point in Chart Editor) ?
Post by Pep » Mon Oct 11, 2004 1:49 pm
Hi Juri,
in case you modify the sources you will have to remove the packages from the package list, open the Tee5D6 package from the list and rebuild it, you can find a install.txt file with all the instructions to recompile and install the packages under :
C:\Program Files\TeeChart Pro v502 for Delphi 6
Juri
Thank You
Post by Juri » Tue Oct 12, 2004 7:28 am
Hi, Pep.
Thank You for your patiance.
