TRoseChart Zoom
Sean Palmer
TRoseChart Zoom
Post by Sean Palmer » Tue Sep 10, 2013 10:24 am
I would like to zoom in on a Rose Chart but when I zoom in using the mouse wheel chart only zooms on one axis, is there any way to force it to do this correctly and also clip the rose to the bounds of the circle?
Sean.
Re: TRoseChart Zoom
Post by Yeray » Thu Sep 12, 2013 3:53 pm
I can't reproduce no one of the reported issues with the following code and TeeChart v2013.08:
uses TeeRose;
var Chart1: TChart;
var i: Integer;
  Chart1:=TChart.Create(Self);
  Chart1.Parent:=Self;
  Chart1.Align:=alClient;
  Chart1.View3D:=false;
  for i:=0 to 4 do
  with Chart1.AddSeries(TRoseSeries) as TRoseSeries do
    FillSampleValues;
    Pointer.Visible:=false;
What TeeChart version are you using?
Could you please arrange a simple example project we can run as-is to reproduce the problems here?
Sean Palmer
Re: TRoseChart Zoom
Post by Sean Palmer » Tue Sep 24, 2013 9:36 am
The same problem also occurs in the TeeChart Pro Examples app, just scroll your mouse wheel over the rose chart...
I am using Build 2013.08.130521
Sean.
Re: TRoseChart Zoom
Post by Narcís » Tue Sep 24, 2013 10:40 am
Hi Sean,
Thanks for your feedback. I could reproduce the issue here and added it (TV52016726) to the defect list to be implemented in future releases.
You can clip the rose to the chart rectangle bounds like this:
procedure TForm2.Series1AfterDrawValues(Sender: TObject);
  Chart1.Canvas.UnClipRectangle;
procedure TForm2.Series1BeforeDrawValues(Sender: TObject);
  Chart1.Canvas.ClipRectangle(Chart1.ChartRect);
Re: TRoseChart Zoom
Post by Narcís » Wed Nov 13, 2013 3:17 pm
Hi Sean,
As an update, setting TChart.ClipPoints to true already clips the series, for example:
  Chart1.ClipPoints:=True;
