With the new 2014 VCL Pro sourcecode version I get a wrong legend like this
Is there a solution for GDI+ ?
Switching to GDI gives a correct display.
Best regards
Uli (XE4)
GDI+ wong legend display
Re: GDI+ wong legend display
Hi Uli,
I'm not able to reproduce it neither using a VCL application nor a FMX application. Can you please attach a simple example project we can run "as-is" to reproduce the problem here?
Hallo,
I use the TeeChart Pro v2015.16.150901 32bit VCL with D2007 and have the same problem. This happens only if the AntiAliasText is set to gpfNormal. Also i have a problem when i want to print the chart.
- charttestdyn.zip
- This example creates a chart and at the bottom three buttons. The first button Changes the AntiAliasText of the TeeGDIPlus-Componenten from gpfDefault to gpfNormal. The second button toggles the GDI+Active. The third one prints the chart.
- (505.21 KiB) Downloaded 655 times
I see the legend checkboxes are drawn displaced to the top when AntiAliasText is set to gpfNormal in GDIPlus, so I've updated the ticket and the test project in it:
http://bugs.teechart.net/show_bug.cgi?id=1430
In the meanwhile, you can use gpfBest, gpfDefault or gpfClearType that seem t work fine.
can you also comprehend the problem with the printing?
http://bugs.teechart.net/show_bug.cgi?id=1628
You are right. I've added it to the public tracker:Steve wrote:can you also comprehend the problem with the printing?
