Add custom control to Tchart legend
Kai
Post by Kai » Mon Apr 07, 2014 12:52 pm
We are using the TeeChartStandard2014 package.
Is it possible to create a custom legend and add a custom control like a TComboBox to the legend?
Kai
Re: Add custom control to Tchart legend
Post by Yeray » Mon Apr 07, 2014 3:20 pm
Hi Kagi,
Kai wrote:Is it possible to create a custom legend and add a custom control like a TComboBox to the legend?
You could try to create a TComboBox in the TChart and position manually. Ie:
uses Series, StdCtrls;
var Chart1: TChart;
    ComboBox1: TComboBox;
var i: Integer;
  Chart1:=TChart.Create(Self);
  Chart1.Parent:=Self;
  Chart1.Align:=alClient;
  Chart1.View3D:=false;
  ComboBox1:=TComboBox.Create(Self);
  ComboBox1.Parent:=Chart1;
  ComboBox1.OnChange:=ComboBox1Change;
  for i:=0 to 4 do
    with Chart1.AddSeries(TFastLineSeries) do
      FillSampleValues;
      Title:='Series' + IntToStr(i);
    ComboBox1.AddItem(Chart1[i].Title, Chart1[i]);
  Chart1.Draw;
  ComboBox1.Left:=Chart1.Legend.Left;
  ComboBox1.Top:=Chart1.Legend.Top-25;
  ComboBox1.Width:=Chart1.Legend.Width;
  ComboBox1.ItemIndex:=0;
  ComboBox1Change(Self);
procedure TForm1.ComboBox1Change(Sender: TObject);
var i: Integer;
  if (ComboBox1.ItemIndex>-1) and (ComboBox1.ItemIndex<Chart1.SeriesCount) then
      Chart1[i].Active:=false;
    Chart1[ComboBox1.ItemIndex].Active:=true;
Kai
Post by Kai » Tue Apr 08, 2014 2:34 pm
thank you for the answer.
I add also this to OnAfterDraw()
if ComboBox1.Visible then
 ComboBox1.Left := Chart1.Legend.Left + 2;
 ComboBox1.Top := Chart1.Legend.Top + 2;
 ComboBox1.Width := Chart1.Legend.Width - 4;
 ComboBox1.BringToFront;
to have the new position after form resize. Then it works perfect.
