TestAlways
- Advanced
Post
by TestAlways » Fri Apr 11, 2014 3:25 pm
2014.11.140409 (This took a long time to figure out how to reproduce! )
In the attached demo, the image created from the has a slight bevel/shadow line on the bottom and left of the chart:
This did not occur in the previous version.
One thing we have done in code to create the image is to use a TTeeCanvas3D (verses the TGDIPlusCanvas). The WMF images created from the GDI Plus canvas created significant problems with our report engine.
Ed Dressel
- Create Image Margin Problem.zip
- (47.97 KiB) Downloaded 627 times
Post
by Yeray » Mon Apr 14, 2014 3:41 pm
Hello Ed,
If I comment out this line at the beginning of your AssignChartToGraphic procedure:
//aChart.Canvas := TTeeCanvas3D.Create;
And I add this line inside the loop in the same procedure:
TPieSeries(aChart.Series[I]).Shadow.Visible:=false;
Both issues disappear, isn't it?
TestAlways
- Advanced
Post
by TestAlways » Mon Apr 14, 2014 3:50 pm
But like I said at the bottom of the original post, if I use the default canvas (TGDIPlusCanvas), the images typically[1] do not show up in my report engine (ReportBuilder) when I save to a PDF. So that is not an option--I have to use the TTeeCanvas3D.
[1] It is a very strange problem. I spent hours trying to produce a demo for Digital Metaphors to work with but could not get it to occur. It is better than it was a month ago, but no charts showing up isn't a good problem.
Post
by Yeray » Tue Apr 15, 2014 2:09 pm
Hello Ed,
TestAlways wrote:But like I said at the bottom of the original post, if I use the default canvas (TGDIPlusCanvas), the images typically[1] do not show up in my report engine (ReportBuilder) when I save to a PDF. So that is not an option--I have to use the TTeeCanvas3D.
I've found an alternative workaround to hide the bevel. You can set this at your Create override:
TestAlways
- Advanced
Post
by TestAlways » Tue Apr 15, 2014 2:40 pm
Thank you. I will try it.
Note that this problem did not occur in previous versions of TChart.
Ed Dressel
TestAlways
- Advanced
Post
by TestAlways » Wed Apr 23, 2014 3:02 pm
We use the charts in our reports, and the reports may have a water mark. Setting the color to clWhite hides the watermark. So while this solution fixes the problem, it creates another.
Is this something that will be fixed soon?
Thank you for your responsiveness.
Ed Dressel
Post
by Yeray » Thu Apr 24, 2014 10:42 am
Hi Ed,
I've investigated a bit more to try to find where the problem comes from, and I've added it to the tracker:
http://bugs.teechart.net/show_bug.cgi?id=739
