exporting to excel
Patrik
exporting to excel
Post by Patrik » Tue Nov 02, 2004 11:43 am
Hi!
I want to export the data in a chart to excel. I use this code:
with TSeriesDataXLS.Create(chart1,nil) do
try
includeindex:=true;
IncludeHeader := True;
IncludeLabels := True;
CopyToClipboard;
finally
Free;
but it doesn't work. When I paste in Excel I get empty cells. The number of empty cells differs so it does something. If my piechart for instance has 4 pieces I get 4 empty cells and so on.
If I change "CopyToClipboard;" to "SaveToFile('c:\test.xls');" it works but
I would like to avoid the actual excel-file. The users of my application have to be able to copy the chart-data into an existing excel document.
What do I do wrong?
/Patrik
Post by Pep » Tue Nov 02, 2004 4:02 pm
Hi Patrik,
to do a copy/paste of the data to Excel file you must export the data as text to a ClipBoard and then you will be able to paste it on excel sheet.
Patrik
Post by Patrik » Wed Nov 03, 2004 8:55 am
Thanks for ur answer, but how do I do that? I thought the CopyToClipboard command did exactly that.
Some example code or a link do some other help would be much appreciated.
Post by Pep » Wed Nov 03, 2004 11:22 am
Hi Patrik,
you can use the following code :
     with TSeriesDataText.Create(Chart1,nil) do
     try
       TextDelimiter:=',' ;  { try also: TeeTabDelimiter }
       IncludeIndex:=true;
       CopyToClipBoard;
     finally
       Free;
