Which to use?: TWaterFallSeries vs. TPoint3DSeries
steve lacerte
Post by steve lacerte » Thu Nov 04, 2004 1:24 am
In a recent post, I was having an issue with the maximim grid size ( 2000x2000, according to the MaxAllowedCells const in TeeChart v5.02 ) that exists for the TWaterFallSeries since I'm trying to exceed that number of data values on the X axis. I have since realized that because all I'm REALLY trying to do is display a series of simple ( no surfaces, just lines ) data lines in 3D fashion, that the use of TWaterFallSeries is perhaps overkill, since it's a TSurfaceSeries derivative. By setting various properties to each TWaterFallSeries, I was able to achieve the simple data line look that I desired, it's just that I hit the above limitation with large series. It seems that what I can ( and should? ) more appropriately use is a bunch of TPoint3DSeries objects to represent my simple series lines in 3D fashion. Correct? ( this is my 1st question )
Assuming this is correct, I try this in a test app by displaying 5 TPoint3DSeries lines on 5 different Z-orders in a TChart that is set up to be 3D. It seems to display quite nicely except for the following feature that I wonder how to "turn off".
As stated above, all I want to display is simple lines but the series lines display ( apparently by default ) with little colored boxes at each series point. Is there any way to remove these? ( this is my 2nd question )
Thanks!
Marjan
Post by Marjan » Thu Nov 04, 2004 9:08 am
Hi, Steve.
Yes. Or alternatively, list of regular line series, each with different Z position (in case z are indexed integers i.e. 0,1,2,3,4...). If this is not the case, the using collection of TPoint3DSeries is the way to go.
The following code should hide point border:
point3DSeries1.Pointer.Pen.Visible := False;
Or if you want to remove series pointers all together, set point3DSeries Pointer.Visible property to False;
Marjan Slatinek,
