Exception when changing chart type in the Chart Editor
Metman
Post by Metman » Mon Jul 21, 2014 8:43 am
Hi
I haven't checked your bug tracker but it may no one else has reported it, so here goes.
In the Chart Editor in the IDE when you attempt to change the type of an existing chart say from a line to bar using the 'Change...' button an exception occurs and a dialog opens. I have filled in the report many times and sent it back to you - in fact I now no that this a useless feature and I have to delete the series and add another because that at least still works.
I am using the latest version of TeeChart on a Windows 7 PC using Delphi XE6.
Bruce.
Re: Exception when changing chart type in the Chart Editor
Post by Sandra » Mon Jul 21, 2014 3:04 pm
Hello Bruce,
The problem you are experiencing is a known bug for us with number ID753 that is already fixed for next maintenance releases of TeeChart Pro VCL/FMX . Also, If you are a source code customer we can send you a test version. If that's the case, please send an email to info at steema dot com with your licensing details and a reference to this thread.
Thanks in advance,
