This email was sent 7 days ago, I do understand that you folks are busy, but some response would be nice ;
Hi Narcis,
There seems to be a problem with installing the latest version TeeChart Pro 2014 on Delphi XE6 latest version.
After recompiling a fresh startup of Delphi; see picture ‘Teechart1.png’. Once in de IDE try to activate the VCL package see picture ‘Teechart2.png’.
I had hoped that recompiling would solve this issue. That is clearly not the case. The beta version runs. Just to be sure there were no virus checkers active.
I hope that you can help solving this issue.
The current installation simply doesn't work on Delphi XE6. 'The beta version runs' (only XE5).
Best regards
Ernest
Installation TeeChart v2014
Re: Installation TeeChart v2014
Hello Ernest,
Steema's support staff are on holiday rotation during this period. If you sent the email directly to Narcís' personal account it is likely that you haven't received a reply for that reason. We recommend that support enquiries come directly to this forum where we are able to provide managed coverage.
TeeChart is fully supported on XE6 so we're not expecting any special issues. We'll need to get a better understanding of the environment setup on your machine. Where you mention that the Beta version runs, that refers to TeeChart's Beta? Is that fully uninstalled? Please check that there are no errant paths to it in the XE6 IDE (or was that exclusivel installed to XE5?). Are you able to put the two images you mention up to this thread?
With thanks.
With thanks.
Hi mark,
The machine I'm running is Windows 7, with Delphi XE6 Enterprise with update 1. Removed all Teechart components and all path reverences from Delphi XE6. Deactivated the virus checker (Avast gave some problems in the past). Then a fresh install of teechart 2014 (140514) latest full source version (TeeChart2014SourceCode.exe). After this install, Recompile.exe (run as an administrator) selected only XE6 as IDE and selected all pachages except 'Decision Cube' . Pressed begin and waited for the result;
TeeChart Pro
Compilation started: 30-7-2014 10:12:33
Win32 v20 Enterprise (Delphi XE6 and C++Builder XE6 Update 1)
Tee920
Embarcadero Delphi for Win32 compiler version 27.0
Copyright (c) 1983,2014 Embarcadero Technologies, Inc.
88464 lines, 0.56 seconds, 960404 bytes code, 4556 bytes data.
TeeUI920
80156 lines, 0.50 seconds, 622332 bytes code, 1368 bytes data.
TeeDB920
8535 lines, 0.20 seconds, 88480 bytes code, 288 bytes data.
TeePro920
210135 lines, 3.07 seconds, 1309380 bytes code, 6476 bytes data.
TeeGL920
16544 lines, 0.23 seconds, 131324 bytes code, 3156 bytes data.
TeeImage920
24975 lines, 0.27 seconds, 319140 bytes code, 11380 bytes data.
TeeWorld920
3513 lines, 0.22 seconds, 29392 bytes code, 300 bytes data.
TeeLanguage920
83655 lines, 0.41 seconds, 3406180 bytes code, 3500 bytes data.
DclTee920
8321 lines, 0.48 seconds, 153112 bytes code, 348 bytes data.
DclTeePro920
5017 lines, 0.58 seconds, 201088 bytes code, 464 bytes data.
DclTeeProStd920
10819 lines, 0.56 seconds, 175648 bytes code, 444 bytes data.
TeeMaker120
86845 lines, 0.67 seconds, 823412 bytes code, 12760 bytes data.
DclTeeMaker120
951 lines, 0.64 seconds, 18808 bytes code, 204 bytes data.
FMXTee920
82503 lines, 0.94 seconds, 902952 bytes code, 4188 bytes data.
FMXTeeUI920
65261 lines, 1.23 seconds, 533660 bytes code, 1080 bytes data.
FMXTeeDB920
8437 lines, 0.27 seconds, 91416 bytes code, 288 bytes data.
FMXTeePro920
161229 lines, 0.98 seconds, 1296228 bytes code, 5912 bytes data.
FMXTeeLanguage920
83676 lines, 0.48 seconds, 3406392 bytes code, 3500 bytes data.
DclFMXTee920
4411 lines, 0.58 seconds, 118864 bytes code, 268 bytes data.
DclFMXTeePro920
2005 lines, 0.72 seconds, 145132 bytes code, 288 bytes data.
16183 lines, 0.55 seconds, 186766 bytes code, 372 bytes data.
DclFMXTeeProStd920
5351 lines, 0.72 seconds, 126332 bytes code, 284 bytes data.
Compilation started: 30-7-2014 10:13:16
TeeTree2D20Tee9
46627 lines, 0.37 seconds, 624536 bytes code, 1496 bytes data.
FMXTree20
16225 lines, 0.27 seconds, 168504 bytes code, 368 bytes data.
DclTree2D20Tee9
1538 lines, 0.27 seconds, 14712 bytes code, 240 bytes data.
DclFMXTree20
825 lines, 0.30 seconds, 8880 bytes code, 188 bytes data.
TeeChart Installation
VERSION: 2014
Installing...
Win32 v20 Enterprise (Delphi XE6 and C++Builder XE6 Update 1) OK. Time: 45s
Win64 v20 Enterprise (Delphi XE6 and C++Builder XE6 Update 1)
Tee920
Embarcadero Delphi for Win64 compiler version 27.0
88464 lines, 2.18 seconds, 1473752 bytes code, 93024 bytes data.
TeeUI920
80156 lines, 1.23 seconds, 908120 bytes code, 55096 bytes data.
TeeDB920
8535 lines, 3.25 seconds, 145320 bytes code, 8752 bytes data.
TeePro920
210135 lines, 3.15 seconds, 2003816 bytes code, 106012 bytes data.
TeeGL920
16544 lines, 0.42 seconds, 187896 bytes code, 13332 bytes data.
TeeImage920
24975 lines, 0.81 seconds, 467720 bytes code, 43436 bytes data.
TeeWorld920
3513 lines, 0.28 seconds, 52840 bytes code, 3092 bytes data.
TeeLanguage920
83655 lines, 1.70 seconds, 4516744 bytes code, 12084 bytes data.
897 lines, 4.66 seconds, 30978 bytes code, 3996 bytes data.
1608 lines, 0.23 seconds, 40068 bytes code, 5356 bytes data.
TeeMaker120
86845 lines, 1.97 seconds, 1187096 bytes code, 80172 bytes data.
Binding Units
3430 lines, 3.87 seconds, 196634 bytes code, 29996 bytes data.
FMXTee920
82503 lines, 3.77 seconds, 1383240 bytes code, 85984 bytes data.
FMXTeeUI920
65261 lines, 2.54 seconds, 786552 bytes code, 44432 bytes data.
FMXTeeDB920
8437 lines, 0.42 seconds, 150648 bytes code, 8836 bytes data.
FMXTeePro920
161229 lines, 4.32 seconds, 1969528 bytes code, 109284 bytes data.
FMXTeeLanguage920
83676 lines, 1.79 seconds, 4517528 bytes code, 12192 bytes data.
16183 lines, 4.91 seconds, 305616 bytes code, 38536 bytes data.
Binding Units
3433 lines, 0.91 seconds, 195869 bytes code, 29996 bytes data.
Compilation started: 30-7-2014 10:14:05
TeeTree2D20Tee9
46627 lines, 0.98 seconds, 854344 bytes code, 37836 bytes data.
VERSION: 2014
Installing...
Win64 v20 Enterprise (Delphi XE6 and C++Builder XE6 Update 1) OK. Time: 48s
Mac OSX v20 Enterprise (Delphi XE6 and C++Builder XE6 Update 1)
FMXTee920
Embarcadero Delphi for Mac OS X compiler version 27.0
82503 lines, 4.46 seconds, 1066696 bytes code, 389468 bytes data.
FMXTeeUI920
65261 lines, 2.34 seconds, 527288 bytes code, 279764 bytes data.
FMXTeeDB920
8437 lines, 0.34 seconds, 96416 bytes code, 44568 bytes data.
FMXTeePro920
161229 lines, 2.01 seconds, 1399536 bytes code, 532604 bytes data.
FMXTeeLanguage920
83676 lines, 0.53 seconds, 3750148 bytes code, 4776 bytes data.
16183 lines, 7.35 seconds, 294231 bytes code, 372 bytes data.
Binding Units
3433 lines, 6.94 seconds, 209850 bytes code, 4 bytes data.
VERSION: 2014
Installing...
Mac OSX v20 Enterprise (Delphi XE6 and C++Builder XE6 Update 1) OK. Time: 28s
iOS Simulator v20 Enterprise (Delphi XE6 and C++Builder XE6 Update 1)
FMXTee920
Embarcadero Delphi Next Generation for iPhone Simulator compiler version 27.0
82503 lines, 0.73 seconds, 0 bytes code, 0 bytes data.
FMXTeeUI920
65261 lines, 0.78 seconds, 0 bytes code, 0 bytes data.
FMXTeeDB920
8437 lines, 0.33 seconds, 0 bytes code, 0 bytes data.
FMXTeePro920
161229 lines, 1.16 seconds, 0 bytes code, 0 bytes data.
FMXTeeLanguage920
83676 lines, 0.45 seconds, 0 bytes code, 0 bytes data.
16183 lines, 5.74 seconds, 330191 bytes code, 372 bytes data.
Binding Units
3433 lines, 2.85 seconds, 233129 bytes code, 4 bytes data.
VERSION: 2014
Installing...
iOS Simulator v20 Enterprise (Delphi XE6 and C++Builder XE6 Update 1) OK. Time: 15s
iOS Device v20 Enterprise (Delphi XE6 and C++Builder XE6 Update 1)
FMXTee920
Embarcadero Delphi Next Generation for iPhone compiler version 27.0
82503 lines, 21.79 seconds.
FMXTeeUI920
65261 lines, 78.42 seconds.
FMXTeeDB920
8437 lines, 8.80 seconds.
FMXTeePro920
161229 lines, 102.24 seconds.
FMXTeeLanguage920
83676 lines, 43.06 seconds.
16183 lines, 5.69 seconds.
Binding Units
3433 lines, 3.03 seconds.
VERSION: 2014
Installing...
iOS Device v20 Enterprise (Delphi XE6 and C++Builder XE6 Update 1) OK. Time: 4m 26s
Android v20 Enterprise (Delphi XE6 and C++Builder XE6 Update 1)
FMXTee920
Embarcadero Delphi for Android compiler version 27.0
82503 lines, 20.94 seconds.
FMXTeeUI920
65261 lines, 67.00 seconds.
FMXTeeDB920
8437 lines, 7.88 seconds.
FMXTeePro920
161229 lines, 101.17 seconds.
FMXTeeLanguage920
83676 lines, 51.70 seconds.
16183 lines, 4.87 seconds.
Binding Units
3433 lines, 2.84 seconds.
VERSION: 2014
Installing...
Android v20 Enterprise (Delphi XE6 and C++Builder XE6 Update 1) OK. Time: 4m 20s
Total time: 664128 msec.
Finally starting Delphi XE6 => error.
Hope you can help.
Best regards,
Ernest
TeeChart Pro
Tee920
TeeUI920
TeeDB920
TeePro920
TeeGL920
TeeImage920
TeeWorld920
TeeLanguage920
DclTee920
DclTeePro920
DclTeeProStd920
TeeMaker120
DclTeeMaker120
FMXTee920
FMXTeeUI920
FMXTeeDB920
FMXTeePro920
FMXTeeLanguage920
DclFMXTee920
DclFMXTeePro920
DclFMXTeeProStd920
TeeTree2D20Tee9
FMXTree20
DclTree2D20Tee9
DclFMXTree20
VERSION: 2014
Installing...
Tee920
TeeUI920
TeeDB920
TeePro920
TeeGL920
TeeImage920
TeeWorld920
TeeLanguage920
TeeMaker120
Binding Units
FMXTee920
FMXTeeUI920
FMXTeeDB920
FMXTeePro920
FMXTeeLanguage920
Binding Units
TeeTree2D20Tee9
VERSION: 2014
Installing...
FMXTee920
FMXTeeUI920
FMXTeeDB920
FMXTeePro920
FMXTeeLanguage920
Binding Units
VERSION: 2014
Installing...
FMXTee920
FMXTeeUI920
FMXTeeDB920
FMXTeePro920
FMXTeeLanguage920
Binding Units
VERSION: 2014
Installing...
FMXTee920
FMXTeeUI920
FMXTeeDB920
FMXTeePro920
FMXTeeLanguage920
Binding Units
VERSION: 2014
Installing...
FMXTee920
FMXTeeUI920
FMXTeeDB920
FMXTeePro920
FMXTeeLanguage920
Binding Units
VERSION: 2014
Installing...
Hope you can help.
Best regards,
Ernest
- Teechart2.png (193.59 KiB) Viewed 8844 times
- Teechart1.png (31.21 KiB) Viewed 8829 times
Hello Ernest,
Many thanks for the information.
The error message "Cannot load package Tee9XX. It contains unit *, which is also contained in package Tee9XX0" indicates that the TeeChart package that was shipped with the IDE (Tee9XX0) is still trying to be loaded, and this creates a conflict with the version you've just installed.
Note XX above refers to the IDE number. For XE6 it's 20, XE5 was 19, XE4 was 18,...
I am seeing in the attached image, the FastReports packages are active, I think this can be the problem, so that are still using the old TeeChart versions. You could try disabling them and enabling new TeeChart packages.
Hoping it will help.
Thanks in advance,
Thanks in advance,
Hi Sandra,
You're completely right ! FastReport VCL is causing this problem.
Hmm.. one problem solved, one new problem created
Thanks !
Best regards,
Ernest
Thanks !
Best regards,
Ernest
Hello Ernest,
I am glad that our suggestion has helped you to solve the problem.
The thread below give you an idea as you need do to solve the problem you are experiencing with Fast Report.
http://www.teechart.net/support/viewtop ... ort#p66296
Thanks in advance,
Regards.
Thanks in advance,
Regards.
