Same size per unit at X and Y axis
ClausB
Post by ClausB » Sun Aug 10, 2014 10:37 am
Hi, I'm using TeeChart Standard v2013/14 and Delphi XE6.
On a chart, I use both bubbles and points. The chart is anchored on the form at left, top, right and bottom so the chart expands with the form. This means that one unit (eg 100 meters) on the X axis is a different length (measured in pixels or cm) than on the Y-axis when you resize the form. This is not a problem with only points series, but with bubbles series is the radius distorted.
How do I lock the X and Y axis together so for example 100 meters in the X-direction always is as long as 100 meters in the Y reningen measured with a ruler on the screen?
Best regards
Claus
Re: Same size per unit at X and Y axis
Post by Yeray » Mon Aug 11, 2014 2:11 pm
Hi Claus,
There is an example in the features demo that makes the axes Isometric. Find it under "All features\Welcome !\Axes\Isometric Axis".
The features demo is shipped with the binary installation. You should find a shortcut to it in the Steema Software programs group, in the StartMenu.
ClausB
Post by ClausB » Tue Aug 12, 2014 5:26 am
Hi Yeray, thank you very much, it works perfect.
Best regards Claus
