Steema exception when trying to change a chart series
Posted: Wed Aug 27, 2014 6:54 pm
by 9235878
Without warning I can no longer no longer change the type for a chart series. I right click on a chart and select "Edit Chart". I then select a series and click on "Change". At this point I get a "Steema Exception" form stating
"Our sincere apologies, an exception has happened ........ Err: List index out of bounds (3)".
Several weeks ago I upgraded TeeChart Pro and installed "v2014.11.140512 32bit VCL". This is a mature project that I have been working on for over a year without any chart issues. (I also have TMS Component Set and RichView installed.) But this also occurs when I add a chart to the main form of a new project.
Any ideas? I am desperate as I am demonstrating the software to my client next week.
Paul
Re: Steema exception when trying to change a chart series
Posted: Thu Aug 28, 2014 7:48 am
by 16568263
I am experiencing exactly the same problem!
It can be reproduced in a 1 form + 1 tchart project...
Any ideas on how to solve this?
Thanks in advance
Christian, DHI
Posted: Thu Aug 28, 2014 8:41 am
This was identified
here.
As NarcĂs said in the public tracker
B753, we can send a test version to the source code customers asking for it.
Posted: Thu Aug 28, 2014 8:51 am
by 16568263
Ok thanks - didn't now it was identified...
Anyway found a fix - so I dont need to install new stuff... (if you have the source)
In the "VCLTee.TeeGally" unit make sure the selected tabsheet for TabTypes is "Series" - shown in attachment, then it Works...
Christian, DHI
Posted: Sat Aug 30, 2014 2:36 pm
by 9235878
I made sure that the Series tab was selected (I clicked on Add series to do this), but I still get the same error. See attached gifs.
This seems like a major major issue that should be fixed immediately and a new build offered to paying clients. I have now lost all ability to change the type for a series.
Paul
- TeeChart change series error.gif (35.39 KiB) Viewed 9206 times
- TeeChartGallery.gif (70.29 KiB) Viewed 9200 times
Posted: Mon Sep 01, 2014 8:33 am
Hi Paul,
Paul wrote:I made sure that the Series tab was selected (I clicked on Add series to do this), but I still get the same error. See attached gifs.
I assume the workaround Christian suggested was to be applied on the sources, not on the binary version.
Paul wrote:This seems like a major major issue that should be fixed immediately and a new build offered to paying clients. I have now lost all ability to change the type for a series.
Please, tell us what IDE are you using and we'll try to prepare a test installer for you.
Posted: Mon Sep 22, 2014 6:01 pm
by 9235878
I am using Rad XE.
Posted: Tue Sep 23, 2014 1:19 pm
Hi Paul,
We are uploading the v2014.12 installers and we'll publish them asap.
