Without warning I can no longer no longer change the type for a chart series. I right click on a chart and select "Edit Chart". I then select a series and click on "Change". At this point I get a "Steema Exception" form stating
"Our sincere apologies, an exception has happened ........ Err: List index out of bounds (3)".
Several weeks ago I upgraded TeeChart Pro and installed "v2014.11.140512 32bit VCL". This is a mature project that I have been working on for over a year without any chart issues. (I also have TMS Component Set and RichView installed.) But this also occurs when I add a chart to the main form of a new project.
Any ideas? I am desperate as I am demonstrating the software to my client next week.
Paul
Steema exception when trying to change a chart series
Re: Steema exception when trying to change a chart series
I am experiencing exactly the same problem!
It can be reproduced in a 1 form + 1 tchart project...
Any ideas on how to solve this?
Thanks in advance
Christian, DHI
Thanks in advance
Christian, DHI
This was identified here.
As Narcís said in the public tracker B753, we can send a test version to the source code customers asking for it.
Ok thanks - didn't now it was identified...
Anyway found a fix - so I dont need to install new stuff... (if you have the source)
In the "VCLTee.TeeGally" unit make sure the selected tabsheet for TabTypes is "Series" - shown in attachment, then it Works...
Christian, DHI
Christian, DHI
- Capture.PNG (13.51 KiB) Viewed 9188 times
I made sure that the Series tab was selected (I clicked on Add series to do this), but I still get the same error. See attached gifs.
This seems like a major major issue that should be fixed immediately and a new build offered to paying clients. I have now lost all ability to change the type for a series.
Paul
Paul
Hi Paul,
I assume the workaround Christian suggested was to be applied on the sources, not on the binary version.Paul wrote:I made sure that the Series tab was selected (I clicked on Add series to do this), but I still get the same error. See attached gifs.
Please, tell us what IDE are you using and we'll try to prepare a test installer for you.Paul wrote:This seems like a major major issue that should be fixed immediately and a new build offered to paying clients. I have now lost all ability to change the type for a series.
I am using Rad XE.
Hi Paul,
We are uploading the v2014.12 installers and we'll publish them asap.
