Names of QR Units changed?
GTI
Post by GTI » Thu Oct 09, 2014 5:22 pm
After installing Teechart and recompile the teechar packages in have to recompile my QRDESING packages (because I activate the Teechart directive in QRDESIGN.INC I needed to recompile them)
For recompiole the QRD Packages I needed tochange the uses of the units like:
{$IFDEF Teechart}
QrTee,TeeProcs, TeEngine,Chart,Series,TeeShape,ArrowCha,VGanttCh,BubbleCh,
{$ENDIF}
for:
{$IFDEF Teechart}
QrTee,VCLTee.TeeProcs, VCLTee.TeEngine,VCLTee.Chart,VCLTee.Series,VCLTee.TeeShape,VCLTee.ArrowCha,VCLTee.GanttCh,VCLTee.BubbleCh,
{$ENDIF}
In units like QRDCtrls and others, this is just an example. How you can see above, I had to aggregate the VCLTee. prefix, because Chart.dcu wasn't in my Teechart installation. only was VCLTee.Chart.dcu, so I changed it and with the other units I did the same. With this change QRD packages compiles. But, Is this correct?
Re: Names of QR Units changed?
Post by Yeray » Fri Oct 10, 2014 10:45 am
XE2 introduced the prefixes forcing us to use them. But you can add VCLTee to the "unit scope names" in your project without having to edit every unit using TeeChart:
http://www.teechart.net/support/viewtop ... 277#p61277
GTI
Post by GTI » Tue Oct 14, 2014 5:48 pm
Thanks, I did it!
