Grid Increments greater than a year
xmetman
Post by xmetman » Wed Oct 15, 2014 8:21 am
Hi
I am displaying monthly data from 1931 to 2014 and have set the bottom axis to a fixed one year increment. I have set the grid to medium grey and the minor grid to light grey and made the count to 11 to display vertical lines for each month. That works fine.
Now I would like to show a dark grey line every 10 years to delineate the decades i.e. 1940,1950 etc etc. To do this I try and set the top axis grid to show a dark grey vertical grid line by setting the increment to 3652.5 but because the series starts in 1931 for some reason it marks up the years 1939,1949 etc and not the decade start/end. Is there anyway I can make this work perhaps by some how manually controlling the grid drawing?
Bruce.
Re: Grid Increments greater than a year
Post by Yeray » Wed Oct 15, 2014 11:48 am
Hi Bruce,
If I understand you correctly, you have something like this:
uses Series, DateUtils;
var i: Integer;
    tmpDate: TDate;
  Chart1.Align:=alClient;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  with Chart1.AddSeries(TLineSeries) as TLineSeries do
    XValues.DateTime:=true;
    tmpDate:=StrToDate('1/1/1931');
    AddXY(tmpDate, 1000+random*50);
    for i:=1 to 2014-1931 do
      tmpDate:=IncYear(tmpDate);
      AddXY(tmpDate, YValue[i-1] + random*10-5);
  with Chart1.Axes.Bottom do
    Increment:=DateTimeStep[dtOneYear];
    DateTimeFormat:='yyyy';
    LabelsAngle:=90;
    MinorTickCount:=11;
    Grid.Color:=clMedGray;
    MinorGrid.Visible:=true;
    MinorGrid.Color:=clLtGray;
That, zooming a bit looks like this:
To highlight the decades, you could use TColorLineTools:
uses Series, DateUtils, TeeTools;
  procedure addColorLineIfDecade(year: Integer);
    if year mod 10 = 0 then
      if (Chart1.Tools.Count=0) or
         ((Chart1.Tools[Chart1.Tools.Count-1] as TColorLineTool).Value<>year) then
         with Chart1.Tools.Add(TColorLineTool) as TColorLineTool do
           Axis:=Chart1.Axes.Bottom;
           Value:=StrToDate('1/1/'+IntToStr(year));
           AllowDrag:=false;
var i: Integer;
    tmpDate: TDate;
    addColorLineIfDecade(YearOf(tmpDate));
    LabelsAngle:=90;
    MinorTickCount:=11;
xmetman
Post by xmetman » Wed Oct 15, 2014 3:37 pm
Thanks Yeray :D
I thought that you must know the answer - I bet you've seen most of them in your job over the years :wink:
