TeeGDIPlus was compile with a different version of TeCanvas.
iBlackMX
Post by iBlackMX » Fri Oct 17, 2014 6:51 pm
Hello
Recently I installed the TChartPro v2014.12.140923 on my Delphi 7 and Delphi XE6.
On the Delphi XE6 IDE install wasn't problem at all, it was installed succesfull.
On Delphi 7 installation process was succesfull too, but now one of my project can't compile, it give me the next message: [Fatal Error] U_Graficas.pas(8): Unit TeeGDIPlus was compiled with a different version of TeCanvas.TTeeCanvas3D
I already research into this forum for Help, I remove all old links to TeecharPro 7 but I was not able to compile my project anyway.
Can you help me please?
iBlackMX
Re: TeeGDIPlus was compile with a different version of TeCanvas.
Post by iBlackMX » Sat Oct 18, 2014 12:01 am
Hello
I found my own solution, I checked .cfg and .dof files inside my Delphi 7 project files.
I saw that inside those files "OLD" references to any teechar version remain, so I simply delete the files and VOILA!!!!
Hope this solution works for other users.
Cheers
iBlackMX
Post by iBlackMX » Sat Oct 18, 2014 12:05 am
Here's the content of my .dof file, so you can see clearly the trouble
[FileVersion]
Version=7.0
[Compiler]
A=8
B=0
C=1
D=1
E=0
F=0
G=1
H=1
I=1
J=0
K=0
L=1
M=0
N=1
O=1
P=1
Q=0
R=0
S=0
T=0
U=0
V=1
W=0
X=1
Y=1
Z=1
ShowHints=1
ShowWarnings=1
UnitAliases=WinTypes=Windows;WinProcs=Windows;DbiTypes=BDE;DbiProcs=BDE;DbiErrs=BDE;
NamespacePrefix=
SymbolDeprecated=1
SymbolLibrary=1
SymbolPlatform=1
UnitLibrary=1
UnitPlatform=1
UnitDeprecated=1
HResultCompat=1
HidingMember=1
HiddenVirtual=1
Garbage=1
BoundsError=1
ZeroNilCompat=1
StringConstTruncated=1
ForLoopVarVarPar=1
TypedConstVarPar=1
AsgToTypedConst=1
CaseLabelRange=1
ForVariable=1
ConstructingAbstract=1
ComparisonFalse=1
ComparisonTrue=1
ComparingSignedUnsigned=1
CombiningSignedUnsigned=1
UnsupportedConstruct=1
FileOpen=1
FileOpenUnitSrc=1
BadGlobalSymbol=1
DuplicateConstructorDestructor=1
InvalidDirective=1
PackageNoLink=1
PackageThreadVar=1
ImplicitImport=1
HPPEMITIgnored=1
NoRetVal=1
UseBeforeDef=1
ForLoopVarUndef=1
UnitNameMismatch=1
NoCFGFileFound=1
MessageDirective=1
ImplicitVariants=1
UnicodeToLocale=1
LocaleToUnicode=1
ImagebaseMultiple=1
SuspiciousTypecast=1
PrivatePropAccessor=1
UnsafeType=0
UnsafeCode=0
UnsafeCast=0
[Linker]
MapFile=0
OutputObjs=0
ConsoleApp=1
DebugInfo=0
RemoteSymbols=0
MinStackSize=16384
MaxStackSize=1048576
ImageBase=4194304
ExeDescription=
[Directories]
OutputDir=
UnitOutputDir=
PackageDLLOutputDir=
PackageDCPOutputDir=
SearchPath=;C:\Program Files (x86)\Borland\Delphi7\Componentes\TeeChart.Pro.v7.06\Sources\..\TeeTree\Compiled\Delphi7\Lib;C:\Program Files (x86)\Borland\Delphi7\Componentes\TeeChart.Pro.v7.06\Sources\Compiled\Delphi7\Lib
Packages=vcl;rtl;vclx;indy;inet;xmlrtl;vclie;inetdbbde;inetdbxpress;dbrtl;dsnap;dsnapcon;vcldb;soaprtl;VclSmp;dbexpress;dbxcds;inetdb;bdertl;vcldbx;webdsnap;websnap;adortl;ibxpress;visualclx;visualdbclx;vclactnband;vclshlctrls;dclOfficeXP;ip4000clientvcl7;ip4000v7;dxCoreD7;dxServerModeD7;cxDataD7;cxLibraryD7;dxGDIPlusD7;dxADOServerModeD7;dxDBXServerModeD7;cxEditorsD7;dxmdsD7;dxBarD7;dxBarDBNavD7;dxBarExtDBItemsD7;dxBarExtItemsD7;dxRibbonD7;cxBarEditItemD7;dxdbtrD7;dxtrmdD7;dxDockingD7;dxThemeD7;dxFlowChartD7;cxPageControlD7;dxComnD7;cxPageControldxBarPopupMenuD7;dxTabbedMDID7;dxLayoutControlD7;dxNavBarD7;dxorgcD7;dxdborD7;cxGridD7;cxExportD7;cxPivotGridD7;cxPivotGridChartD7;cxPivotGridOLAPD7;cxTreeListD7;cxTreeListdxBarPopupMenuD7;cxSchedulerD7;cxSchedulerGridD7;dcldxSkinsCoreD7;dxSkinsCoreD7;dxSkinscxPCPainterD7;dxSkinscxSchedulerPainterD7;dxSkinsdxDLPainterD7;dxSkinsdxBarPainterD7;dxSkinsdxNavBarPainterD7;dxSkinsdxRibbonPainterD7;dxSpellCheckerD7;cxSpreadSheetD7;cxVerticalGridD7;dxPSCoreD7;dxPSLnksD7;dxPScxCommonD7;dxPScxExtCommonD7;dxPScxGridLnkD7;dxPSdxLCLnkD7;dxPScxPivotGridLnkD7;dxPScxSchedulerLnkD7;dxPScxSSLnkD7;dxPScxTLLnkD7;dxPScxVGridLnkD7;dxPSdxOCLnkD7;dxPSdxDBOCLnkD7;dxPSdxDBTVLnkD7;dxPSdxFCLnkD7;dxPScxPCProdD7;dxPsPrVwAdvD7;dxPSPrVwRibbonD7;dxSkinBlackD7;dxSkinBlueD7;dxSkinCaramelD7;dxSkinCoffeeD7;dxSkinDarkRoomD7;dxSkinDarkSideD7;dxSkinFoggyD7;dxSkinGlassOceansD7;dxSkiniMaginaryD7;dxSkinLilianD7;dxSkinLiquidSkyD7;dxSkinLondonLiquidSkyD7;dxSkinMcSkinD7;dxSkinMoneyTwinsD7;dxSkinOffice2007BlackD7;dxSkinOffice2007BlueD7;dxSkinOffice2007GreenD7;dxSkinOffice2007PinkD7;dxSkinOffice2007SilverD7;dxSkinOffice2010BlackD7;dxSkinOffice2010BlueD7;dxSkinOffice2010SilverD7;dxSkinPumpkinD7;dxSkinSevenD7;dxSkinSharpD7;dxSkinSilverD7;dxSkinSpringTimeD7;dxSkinStardustD7;dxSkinSummer2008D7;dxSkinValentineD7;dxSkinXmas2008BlueD7;dxSkinBlueprintD7;dxSkinDevExpressDarkStyleD7;dxSkinDevExpressStyleD7;dxSkinHighContrastD7;dxSkinSevenClassicD7;dxSkinSharpPlusD7;dxSkinTheAsphaltWorldD7;dxSkinVS2010D7;dxSkinWhiteprintD7;dxTileControlD7;rbCIDE127;rbIDE127;rbRCL127;rbBDE127;rbUSERDesign127;rbUSER127;rbDIDE127;rbDAD127;rbDBDE127;rbDB127;rbADO127;rbDBE127;rbIBE127;rbRIDE127;rbRAP127;XFormat9;XDevice9;BE3;GMLib_D7;tmsxlsd7;TMSD7;tmswizd7;tmsexd7;TMSD7PERS;AstaD7;astarcs;Tee77;TeeUI77;TeeDB77;TeePro77;TeeGL77;TeeImage77;TeeLanguage77
Conditionals=
DebugSourceDirs=
UsePackages=0
[Parameters]
RunParams=
HostApplication=
Launcher=
UseLauncher=0
DebugCWD=
[Language]
ActiveLang=
ProjectLang=
RootDir=C:\Program Files (x86)\Borland\Delphi7\Bin\
[Version Info]
IncludeVerInfo=1
AutoIncBuild=0
MajorVer=1
MinorVer=0
Release=0
Build=0
Debug=0
PreRelease=0
Special=0
Private=0
DLL=0
Locale=2058
CodePage=1252
[Version Info Keys]
CompanyName=DeltaMóvil
FileDescription=
FileVersion=1.0.0.0
InternalName=
LegalCopyright=
LegalTrademarks=
OriginalFilename=
ProductName=
ProductVersion=1.0.0.0
Comments=
[Excluded Packages]
c:\program files (x86)\borland\delphi7\Bin\dcldss70.bpl=Borland Decision Cube Components
C:\Users\aleja_000\Documents\DevExpress VCL\Library\Delphi7\dcldxPSTeeChartD7.bpl=ExpressPrinting System ReportLink for TeeChart by Developer Express Inc.
C:\Users\aleja_000\Documents\DevExpress VCL\Library\Delphi7\dcldxPSDBTeeChartD7.bpl=ExpressPrinting System ReportLink for DBTeeChart by Developer Express Inc.
C:\Program Files (x86)\Borland\Delphi7\RBuilder\Lib\dclRBC127.bpl=ReportBuilder TeeChart 4.04 Components
[HistoryLists\hlUnitAliases]
Count=1
Item0=WinTypes=Windows;WinProcs=Windows;DbiTypes=BDE;DbiProcs=BDE;DbiErrs=BDE;
[HistoryLists\hlSearchPath]
Count=1
Item0=;C:\Program Files (x86)\Borland\Delphi7\Componentes\TeeChart.Pro.v7.06\Sources\..\TeeTree\Compiled\Delphi7\Lib;C:\Program Files (x86)\Borland\Delphi7\Componentes\TeeChart.Pro.v7.06\Sources\Compiled\Delphi7\Lib
Post by Yeray » Mon Oct 20, 2014 2:03 pm
I'm glad to hear you found how to solve it.
And thanks for sharing it!
By the way, I see you posted the same here:
http://www.teechart.net/support/viewtop ... 545#p67545
Maybe we can remove those posts for not to confuse others, if you agree.
iBlackMX
Post by iBlackMX » Mon Oct 20, 2014 3:07 pm
Sure, remove it.
