TChart editor errors
sde
Post by sde » Tue Oct 28, 2014 4:45 pm
I am currently using Build 2013.09.131119, so it is possible you have already fixed these concerns. I unfortunately cannot upgrade to the newest version this late in the release cycle for my own product, though, so if you have any workarounds or can confirm this has been addressed already, I would appreciated it.
(1) Chart>Axis>Options>Minimum/Maximum
In previous versions of the software, if you edited the edit box it would automatically deselect "auto" for you. Now it only does this if you use the change button. It would be nice if you went back to automatically deselecting or just remove the edit box completely or the change button completely. My users find it confusing to have two methods and to have them work differently.
(2) Series>marks>Margins
You replaced the spin edit boxes with slider bards and the slider bars have no effect when you move them.
Thanks!
SDE
Re: TChart editor errors
Post by Sandra » Fri Oct 31, 2014 10:15 am
Hello sde,
Currently the check box automatic is deselected when you modify the text box or use the change button. Therefore, in latest maintenance release of TeeChart Pro VCL/FMX build number 2014.12.140923 we consider the behaviour is correct.
The problem is fixed in latest TeeChart Pro VCL/FMX version build number 2014.12.140923.
Thanks in advance,
