dclado210.bpl not found
I have Delphi XE7 Starter with TeeChart 2014 Standard. Each time I open a project with a Chart I get the message "dclado210.bpl not found". If I click ignore, the chart will disappear from my form. I get the same message if I try to add a chart to a form (not a dbchart). If I reinstall Teechart, it works the first time but as soon as I restart Delphi the same problem comes back. Is it because Delphi Starter does not have some database tools? Why does it work the first time after I reinstalled Teechart? Any other idea how to solve this problem?
Re: dclado210.bpl not found
Hello ironphil,
Yes.ironphil wrote:Is it because Delphi Starter does not have some database tools?
Probably because packages are being installed but dependencies not checked.ironphil wrote:Why does it work the first time after I reinstalled Teechart?
Yes, you should use the Starter versions specific packages as Yeray Alonso explained here.ironphil wrote:Any other idea how to solve this problem?
