TBarSeries Date/Time axis
Matias Nabarro
Post by Matias Nabarro » Fri Nov 07, 2014 3:31 pm
Hi. I'm working with last version of Pro VCL chart.
In a chart with several stacked bar series (created by code)
BSeriePCR :=TBarSeries.Create(Chart_CADO);
ChartCADO.AddSeries(BSeriePCR);
BSeriePCR.Multibar :=mbStacked;
BseriePCR.Color :=clPCR;
BSeriePCR.Marks.Visible :=false;
I can't find a way to set [by code ]LeftAxis to be a DateTime axis with 'nn:ss' value.
The only way I can draw the chart the way I need it is, creating in design time one pair of stacked TBarSeries and set in the designer, the left axis to be DateTime.
The problem is that I need to clear all data from the chart before creating an filling the series. Is there any way to set the left axis "DateTime" property I see in design time ?.
Best regards.
Matias.
Re: TBarSeries Date/Time axis
Post by Narcís » Fri Nov 07, 2014 3:43 pm
Hi Matias,
Sure, you can do:
  Series1.YValues.DateTime:=True;
  Series1.GetVertAxis.DateTimeFormat:='nn:ss';
Matias Nabarro
Post by Matias Nabarro » Mon Nov 10, 2014 1:31 pm
Thanks Narcís, it was what I needed.
Best regards.
