Contour plot based on SQL-query
llnck
Post by llnck » Mon Dec 15, 2014 9:39 am
Hi all,
I want to create a contour plot which is linked to an SQL-query.
I'm wondering what will happen, if the query yields multiple values for a given x and y coordinate?
Will only the first or last value be plotted or is an average calculated?
Thanks for a hint
Norbert
Re: Contour plot based on SQL-query
Post by Yeray » Mon Dec 15, 2014 2:22 pm
Hi Norbert,
You should avoid adding repeated values, they aren't allowed as you can read in the procedure SearchXValue at TeeSurfa.pas:
    // Adds unique values of "AValue" to "Values" array.
    // Repeated values aren't allowed.
    Procedure SearchXValue(const Value:TChartValue);
      if SearchSorted(Value,XCount,XVals)=-1 then
        XVals[XCount]:=Value;
        Inc(XCount);
