2012 VCL Out of Memory Error
CPStevenC
Post by CPStevenC » Fri Jan 16, 2015 6:02 pm
Using Delphi 7 , TeeChart PRO v2012.05.120327, with source.
I have an issue where a chart that actually has nothing on it, eventually freaks out and hogs up memory to point of crashing (1.4gb)
Chart has two THighLowLineSeries in it. Which in my case, it should be nothing in them yet.
It seems to happen after resizing the chart a few times.
It gets stuck in a while loop it looks in TeEngine.pas
Line 5710
While tmpValue>=tmp Do
tmpValue is always 0
tmp = -1e-12
soooo, it stis there doing the same thing over and over until it out of memory.
I have not tried to goto 2014 yet, as every time I upgrade teechart after long periods of not updating, it usually is a painful process of fixing things and testing everything all over again.
Is there a fix for this? Or going to 2014 the fix?
Re: 2012 VCL Out of Memory Error
Post by Yeray » Mon Jan 19, 2015 10:00 am
I'm trying to reproduce the problem with TeeChart v2012.05, Delphi 7 and the following code but I can't:
uses Chart, TeeHighLowLine, TeeConst;
var Chart1: TChart;
  Chart1:=TChart.Create(Self);
  Chart1.Parent:=Self;
  Chart1.Align:=alClient;
  Chart1.Title.Text.Text:=TeeMsg_Version;
  Chart1.View3D:=false;
  Chart1.Legend.Visible:=false;
  Chart1.AddSeries(THighLowLineSeries).FillSampleValues();
I'm resizing the form to see if the application crashes or if the memory grows in the Task Manager, but it stays around 800 Kb.
Could you please try to arrange a simple example project we can run as-is to reproduce the problem here?
