Wrond legend display with 2015.14 update
ulibru
Re: Wrond legend display with 2015.14 update
Post by ulibru » Fri Mar 20, 2015 1:59 pm
Hello Yeray,
as I have got no answer till today: did I use a bad language with my last post?
Any news?
BR
Uli
Post by Yeray » Fri Mar 20, 2015 3:19 pm
Hello Uli,
I'd like to apologize for the lack of response here.
I'm afraid I can't tell you when these issues are going to be closed. The time until we can fix a bug or implement a new feature depends on variables such as the complexity of the problem, impact and the number of issues with even higher priority that claims our team attention.
ulibru wrote:It's "just" 16 bugs reported for VCL TeeChart since then still open, only 2 bugs solved.
If you want to send us a list of items we'll be glad to take a look at their status.
Post by Yeray » Thu Apr 16, 2015 9:18 am
Note we've closed the ticket because we haven't found a combination in the test example that reproduces the problem with the internal sources.
Bert Kreisel
Post by Bert Kreisel » Thu Apr 16, 2015 10:05 am
the problem remains with the modified unit chart.pas from 27 Jan 2015, so could I get the internal sources please?
Post by Yeray » Thu Apr 16, 2015 11:28 am
Hi Bert,
I've just sent you a mail with the new modifications.
ulibru
Post by ulibru » Fri Apr 17, 2015 8:17 am
Hello Yeray,
can you please send me the correct source too? I like to test it. Thanks
Uli
Post by Yeray » Fri Apr 17, 2015 9:17 am
Hi Uli,
ulibru wrote:can you please send me the correct source too? I like to test it. Thanks
Sure! Just sent it.
ulibru
Post by ulibru » Fri Apr 17, 2015 11:45 am
Hello Yeray,
many thanks. It seems to work at first sight. :D
If I recognize a further problem I will report.
Best regards
Uli
Post by Yeray » Fri Apr 17, 2015 1:33 pm
Hi Uli,
ulibru wrote:many thanks. It seems to work at first sight. :D
Good news! Thanks for the feedback.
tkoehn
Post by tkoehn » Mon Apr 20, 2015 11:31 pm
We also are having this problem with the Jan 2015 release. How is the latest source/build received? We are using XE7.
Thanks, tkoehn
Post by Yeray » Tue Apr 21, 2015 7:06 am
Hi tkoehn,
tkoehn wrote:We also are having this problem with the Jan 2015 release. How is the latest source/build received? We are using XE7.
I see you also own the TeeChart sources so I'm sending the same files to you.
