Problem using Video Creator tool
emwamin
Post by emwamin » Mon Feb 23, 2015 5:58 pm
Hi
I am using the video creator tool but it crashes every time. I am trying to do it the same way as the demo in Tee9New (which works on my system) using a timer. I wonder what do I do wrong.
I am not rotating the plot like the example in Tee9New but programmatically moving a trackbar. Data Points having the same index as the trackbar position or less get a color (default color is background = Hidden points). The followings are the code:
procedure TMyForm.Timer1Timer(Sender: TObject);
     if trackbar3.Position < trackbar3.Max then
        Begin
             trackbar3.Position := trackbar3.Position + 5;         // Timer trigger 5 times per second so each second 10 more point will become visible
             Application.ProcessMessages;
procedure TMyForm.btnStartAnimation(Sender: TObject);
var
     i,cnt  : Integer;
     delay : Double;  //MS
     trackbar3.Position := 0;
     timer1.Enabled := true;                                              //enabling the timer
     Video.StartRecording('c:\temp\test.avi');                    // Start recording
     while (trackbar3.Position < trackbar3.Max) do             // Wait until all point are plotted
        Begin
             Sleep(500);
     timer1.Enabled := false;
     Video.StopRecording;                                               // Stop recording
procedure TMyForm.TrackBar3Change(Sender)
        // we change the background color here
I have to add that my plot is OpenGL. As soon as I start the program I get an exception. The following is the trace for the function calls (last call at the top):
0048738c +000 VideoTest.exe Graphics TBitmap.GetHandleType
00487414 +008 VideoTest.exe Graphics TBitmap.GetPixelFormat
00488421 +011 VideoTest.exe Graphics TBitmap.SetPixelFormat
007b6e49 +02d VideoTest.exe TeeVideo TVideoTool.InitStreamFormat
007b6d04 +02c VideoTest.exe TeeVideo TVideoTool.AddFrame
007b6a9a +046 VideoTest.exe TeeVideo TVideoTool.ChartEvent
0067b166 +032 VideoTest.exe TeEngine TCustomAxisPanel.BroadcastToolEvent
0067bb27 +1f3 VideoTest.exe TeEngine TCustomAxisPanel.InternalDraw
0065a0e4 +11c VideoTest.exe TeeProcs InnerDraw
0065a199 +021 VideoTest.exe TeeProcs TCustomTeePanel.Draw
00659df9 +041 VideoTest.exe TeeProcs TCustomTeePanel.Draw
0065a265 +059 VideoTest.exe TeeProcs TCustomTeePanel.Paint
004defb7 +057 VideoTest.exe Controls TCustomControl.PaintWindow
004dadce +04e VideoTest.exe Controls TWinControl.PaintHandler
004db2fb +03f VideoTest.exe Controls TWinControl.WMPaint
004def50 +010 VideoTest.exe Controls TCustomControl.WMPaint
004d7bd8 +188 VideoTest.exe Controls TControl.WndProc
004dac37 +157 VideoTest.exe Controls TWinControl.WndProc
0065a84c +00c VideoTest.exe TeeProcs TCustomTeePanel.WndProc
004da8b4 +02c VideoTest.exe Controls TWinControl.MainWndProc
0047e9c8 +014 VideoTest.exe Classes StdWndProc
77440974 +016 user32.dll CallWindowProcW
77975c4b +02b ntdll.dll KiUserCallbackDispatcher
77438b77 +00a user32.dll DispatchMessageA
004f821f +083 VideoTest.exe Forms TApplication.ProcessMessage
004f823e +00a VideoTest.exe Forms TApplication.ProcessMessages
00a189e6 +032 VideoTest.exe MyForm 162 +5 TMyForm.Timer1Timer
Does the size of the plot make any difference?
Please advise how I can solve this problem.
I am using TeeChart version 2015.14.150120. My OS is Vista (32 bits) with service pack 2.
BR
emwamin
emwamin
Re: Problem using Video Creator tool
Post by emwamin » Mon Feb 23, 2015 6:00 pm
Hi
I have to add that I am using Delphi 7.
BR
emwamin
Post by Yeray » Tue Feb 24, 2015 11:48 am
I've made a simple test trying to do what you describe and it seems to work fine for me here.
Could you please take a look at the project attached and modify it so we can reproduce the problem here?
testVideo.zip
(2.25 KiB) Downloaded 434 times
emwamin
Post by emwamin » Thu Feb 26, 2015 10:21 am
Hi
Thanks for the example program. It works on my computer. But as I mentioned I use OpenGL. If you activate openGL you get the same error as me.
Please see the modified example.
BR
emwamin
testVideo.zip
modified example
(31.95 KiB) Downloaded 396 times
Post by Yeray » Fri Feb 27, 2015 12:15 pm
Excuse me, I missed the OpenGL part.
This is a know problem already in the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=175
I've just fixed it so the next maintenance release will include the modification.
If you want to modify the sources yourself, at TeeVideo.pas, include the TeeGLCanvas to the uses clause change TVideoTool.ChartEvent for this:
procedure TVideoTool.ChartEvent(AEvent: TChartToolEvent);
var tmpBitmap: TBitmap;
  inherited;
  if IsRecording and (AEvent=cteAfterDraw) then
  try
    if ParentChart.Canvas is TGLCanvas then
      tmpBitmap:=TBitmap.Create;
      (ParentChart.Canvas as TGLCanvas).BufferToBitmap(tmpBitmap, ParentChart.ChartBounds);
    end
      tmpBitmap:=TTeeCanvas3D(ParentChart.Canvas).Bitmap;
    AddFrame(tmpBitmap);
  except
    on E:Exception do
      StopRecording;
      raise;
emwamin
Post by emwamin » Sat Feb 28, 2015 2:15 pm
Hi
I changed the source and compiled it but the problem remains.
Does the recompilation also install the changed modules? As far as I can see I am using the new DCU file.
BR
emwamin
Post by Yeray » Mon Mar 02, 2015 2:42 pm
Hi emwamin,
emwamin wrote: I changed the source and compiled it but the problem remains.
Yes, TeeRecompile should compile the sources and install the, into the chosen IDE(s).
You can try temporally adding the "Sources" path on top of the IDE library path. This way, you'll be directly using the sources and you'll be able to debug on them.
Post by Yeray » Fri Mar 06, 2015 8:46 am
Yeray wrote: If you want to modify the sources yourself, at TeeVideo.pas, include the TeeGLCanvas to the uses clause change TVideoTool.ChartEvent for this:
We've modified the fix to not use TeeGLCanvas unit. Now TVideoTool.ChartEvent looks like this:
  inherited;
  try
    if ParentChart.Canvas.SupportsFullRotation then //OpenGL
      ParentChart.Canvas.RenderToBitmap(tmpBitmap, ParentChart.ChartBounds);
    end
      tmpBitmap.Free;
  except
    on E:Exception do
      StopRecording;
      raise;
If you modified TeeVideo.pas adding TeeGLCanvas unit in the uses clause as indicated in the post above, don't forget to remove it.
