dear support,
I do have a chart with two series on it, and it seems there is some issue with the legend. Do you know whether this is a known issue and if yes, where can i find the patch, if any?
Attached to this email, a view of the issue.
thanks
wrong legend
wrong legend
- CaptureLegende.PNG (57.66 KiB) Viewed 4880 times
thanks,
Nabil Ghodbane (PhD. Habil)
Re: wrong legend
In addition, some of the legends are completely invisible, whereas with the 2013 version it worked fine.
Is there a patch to solve this issue?
thanks.
thanks.
- CaptureLegende2.PNG (79.96 KiB) Viewed 4872 times
thanks,
Re: wrong legend
Take a look at the discussion here:
http://www.teechart.net/support/viewtop ... =3&t=15397
If you can send us a simple example project we can run as-is to reproduce the problems here, we'll check if they are solved with the internal sources or not.
Since you own the source code version, I've just sent you the modified units so you can replace the according files on TeeChart v2015.14 sources and run TeeRecompile to install and check if those problems are solved or not.
