TeeChart 2015.15**
kmanuele
TeeChart 2015.15**
Post by kmanuele » Fri Apr 24, 2015 7:11 pm
Installed the 2015 upgrade for both XE7 and XE8.
Now am getting unresolved external for Vcltee::Teengine::TChartSeries::GetMarks() in an Pie Chart on an existing XE7 project.
Uninstalled, deleted all Tee files, and reinstalled. Didn't help. Verified no *tee* files in Embarcadero folders
Ideas?
Kevin
Re: TeeChart 2015.15**
Post by Yeray » Mon Apr 27, 2015 9:16 am
Hello Kevin,
Please check the list of packages and the path libraries.
Then, try if a new simple example project works fine for you.
If a new simple project works fine but not your old application, then I'd check the old project files (with notepad or similar) and manually correct any wrong reference you may find on it.
kmanuele
Post by kmanuele » Mon Apr 27, 2015 7:52 pm
Somehow, my project file had the new TeeChart paths, but they were incomplete. Manually fixed, and all is ok now.
Kevin
Post by Yeray » Tue Apr 28, 2015 7:00 am
Hi Kevin,
kmanuele wrote:Somehow, my project file had the new TeeChart paths, but they were incomplete. Manually fixed, and all is ok now.
We'll keep an eye on that. Thanks for the information.
