I use vertical stacked bar charts to plot well lithology, with a custom horizontal axis. This causes the whole chart to be offset to the right. Compare the position of the left vertical axis between a normal line chart and the bar chart. Can you suggest how I might address this.
Errol
Chart offset when plotting stacked bar charts
- LineChart.png (46.37 KiB) Viewed 5833 times
- BarChart.png (35.94 KiB) Viewed 5767 times
Re: Chart offset when plotting stacked bar charts
This seems to work fine for me here:
Are you using the latest TeeChart version, v2015.15?
Could you please modify the code above or to arrange a simple example project we can run as-is to reproduce the problem here?
var i: Integer;
Chart1.Axes.Left.Title.Caption:='Left Axis Title';
for i:=0 to 4 do
FillSampleValues;
MultiBar:=mbStacked;
Marks.Visible:=false;
Hi Yeray
Thanks for your reply to my last post and sorry for the delayed reply. I have since determined that the graph offset is caused by assigning a title to the left axis, using the following command:
YLabelDisplay := ldField;
ldField is the current display name of the axis. I use the same command to assign a title to the left axis of an ordinary line graph and this does not cause the graph to be offset, so I would be grateful if you could suggest a workaround for this problem.
I have attached two graphs showing the offset when a title axis is assigned.
Thanks and regards
Errol
Thanks and regards
Errol
Hi Errol,
