Save Marks text
GE-BB-CB
Save Marks text
Post by GE-BB-CB » Wed May 13, 2015 9:58 am
I use TChart and TSeries for some acquisition of data during a time.
I want to draw marks on some points I have on my series which match with a certain time.
I use the event TSeriesGetMarkText to make visible (MarkText:='Text') or not (MarkText:='') the marks depending on the time.
It works well but at the end, I save my chart in a stream file. When I open this file in an other chart, all marks are visible and the labels match with the YValues of the points.
How can I save the text and the index of the marks I put in the event TSeriesGetMarkText and open it in the right way in an other chart ?
Benoît
Re: Save Marks text
Post by Yeray » Thu May 14, 2015 7:53 am
Hello Benoît,
I'm afraid the exportation can store the design of the chart but not the code in the application.
Instead of using the TSeriesGetMarkText, you could populate the series' Labels array and the empty strings won't be shown. Here you have a simple example:
uses Series, DateUtils;
var i: Integer;
    tmpDate: TDateTime;
    str: string;
  Chart1.Legend.Visible:=false;
  with Chart1.AddSeries(TPointSeries) as TPointSeries do
    XValues.DateTime:=true;
    for i:=0 to 9 do
      str:='';
      tmpDate:=Today+i;
      if (i mod 4 = 0) then
        str:='point ' + IntToStr(i);
      AddXY(tmpDate, 25+random*75, str);
    Marks.Visible:=true;
    Marks.Style:=smsLabel;
GE-BB-CB
Re: Save Marks text
Post by GE-BB-CB » Mon May 18, 2015 2:58 pm
Hello Yeray,
Thanks for your solution, it seems to work well !
Benoît
