WarmBooter
Post
by WarmBooter » Mon May 25, 2015 1:10 pm
I'm using a TDBChart with Crosstab datasource and Bar series. In the chart editor, I can set the marks as not visible and the chart is previewed correctly (without the marks). But in runtime, when the chart is draw, only the marks of the first series are hidden... all the marks of the other series are visible.
I tried to do this, but it didnt help:
myDataset.Open;
myCrossTab.Refresh;
with DBChart11 do
for I := 0 to SeriesCount -1 do
Series[i].Marks.Visible:=false;
Also, the horizontal (bottom) axis is set to DateTime and format MM/yyyy, but it is draw as a full date, without respecting the format.
Any help?
Carlos
WarmBooter
Post
by WarmBooter » Mon May 25, 2015 7:37 pm
Well, I could solve the problem with the Marks... the problem is that that piece of code was inside a DisableControls/EnableControls session, and when EnableControls is called, for some reason, the chart make the series marks visible again.
Still could not solve the Axis format problem.
Post
by Yeray » Tue May 26, 2015 2:05 pm
WarmBooter wrote:Also, the horizontal (bottom) axis is set to DateTime and format MM/yyyy, but it is draw as a full date, without respecting the format.
WarmBooter wrote:Still could not solve the Axis format problem.
Maybe you've set labels on the series. Note that by default the bottom axis labels style is set to "Auto" and this show the series labels if they are populated.
If that's not the case we'll need to see how are you setting your chart, so I'd ask for a simple example project we can run as-is to reproduce the problem here.
WarmBooter
Post
by WarmBooter » Tue May 26, 2015 4:19 pm
The Axis labels are set as Marks, since this was the only way I found to have the desired value printed. The problem is that it doesn't respect the datetime format mask that I had defined.
Post
by Yeray » Wed May 27, 2015 8:25 am
Then the problem will probably be in the formatting of the datetime when you are adding it to the values.
If you are using Add(value, label, color) to add your points to the series, check that "label" string you are entering has the correct string.
The Axis DateTimeFormat is only used when LabelStyle is set to talValue, talPointValue or talAuto (talAuto - without labels on the series).
WarmBooter
Post
by WarmBooter » Wed May 27, 2015 11:43 am
Yeray wrote:Hello,
The source of the data is a query and the chart is configured as crosstab, so all points, etc. are being added automatically.
Problem is that using Value, PointValue or Auto doesnt display the desired value... only setting as Marks did it (almost).
Post
by Yeray » Wed May 27, 2015 1:18 pm
Check the values of the "REFERENTE" field at the "tqCancelamentos" dataset. This field probably contains strings formatted from a date as "dd/mm/yyyy".
WarmBooter
Post
by WarmBooter » Wed May 27, 2015 1:36 pm
Yeray wrote:Hello,
In the dataset, REFERENTE is a TDateField, so, not a string. Also, no displayformat assigned to it.
Carlos
Post
by Yeray » Wed May 27, 2015 4:14 pm
Hi Carlos,
I see TDBCrossTabSource takes the label field set and formats it without considering the Axis DateTimeFormat:
I'm not sure if modifying this would be a good idea. Ie note that having "MM/yyyy" as DateTimeFormat you'd loose the day information and then you wouldn't be able to show the day in the marks or anywhere else.
At this moment, the best workaround I can think on would be using the Chart OnGetAxisLabel to convert the label to DateTime and then back to string using your axis DateTimeFormat. Ie:
uses DateUtils;
procedure TForm1.DBChart1GetAxisLabel(Sender: TChartAxis; Series: TChartSeries;
ValueIndex: Integer; var LabelText: string);
var tmpDate: TDateTime;
if (Sender = DBChart1.Axes.Bottom) then
tmpDate:=StrToDateTimeDef(LabelText, Today);
LabelText:=FormatDateTime(DBChart1.Axes.Bottom.DateTimeFormat, tmpDate);
WarmBooter
Post
by WarmBooter » Wed May 27, 2015 5:42 pm
In my case, this would not be a problem, since the day is always 01. I use that field to represent the month+year that something refers to (day doesn't matter, so it is stored always as day 1).
Carlos
Post
by Yeray » Thu May 28, 2015 11:04 am
Hi Carlos,
Another alternative would be triggering the series' OnAfterAdd event to modify the label of point that has been added. Ie using the "orders" table in the "TeeChart Pro Database" shipped with the installation:
uses Series, DBTables, TeeDBCrossTab, TeeDBCrossTabEditor, DateUtils;
var Series1: TBarSeries;
Table1: TTable;
DBCrossTabSource1: TDBCrossTabSource;
DBChart1.View3D:=false;
DBChart1.Axes.Bottom.DateTimeFormat:='MM/yyyy';
Table1:=TTable.Create(Self);
with Table1 do
DatabaseName:='TeeChart Pro Database';
TableName:='orders';
Filter:='EMPNO=4';
Filtered:=True;
DBCrossTabSource1:=TDBCrossTabSource.Create(Self);
with DBCrossTabSource1 do
DataSet:=Table1;
GroupField:='EMPNO';
LabelField:='SALEDATE';
ValueField:='ITEMTOTAL';
Series1:=DBChart1.AddSeries(TBarSeries) as TBarSeries;
with Series1 do
//OnAfterAdd:=SeriesAfterAdd; // uncomment this to activate the workaround
DataSource:=DBCrossTabSource1;
XValues.DateTime:=True;
DBCrossTabSource1.Series:=Series1;
DBCrossTabSource1.Active:=true;
Table1.Active:=true;
procedure TForm1.SeriesAfterAdd(Sender:TChartSeries; ValueIndex:Integer);
tmpDate:=StrToDateTimeDef(Sender.Labels[ValueIndex], Today);
Sender.Labels[ValueIndex]:=FormatDateTime(DBChart1.Axes.Bottom.DateTimeFormat, tmpDate);
