Panning and pop-up menus
toreba
Post by toreba » Thu Jun 18, 2015 11:14 am
With the conventional use of a pop-up menu on the right mouse click event, I can't use the TChart's automatic panning on the right mouse button, not even if I require e.g. [ssCtrl] in the TeeScrollKeyShift property.
I can't run the pan function on the left mouse button without losing the automatic zoom, again, even using TeeScrollKeyShift.
Is it possible to run the pan function through some other combination of keys so that the user does not have to explicitly switch between zoom and pan modes?
Thanks for any advice!
Toreba
Re: Panning and pop-up menus
Post by Yeray » Thu Jun 18, 2015 3:00 pm
Hello toreba,
This seems to do the trick:
var DownPos: TPoint;
  DownPos.X:=X;
  DownPos.Y:=Y;
procedure TForm1.Chart1MouseUp(Sender: TObject; Button: TMouseButton;
  if (Button=mbRight) and (DownPos.X = X) and (DownPos.Y = Y) then
    PopupMenu1.Popup(GetClientOrigin.X+Chart1.Left+X, GetClientOrigin.Y+Chart1.Top+Y);
  PopupMenu1.AutoPopup := false;
  Chart1.PopupMenu := PopupMenu1;
toreba
Post by toreba » Fri Jun 19, 2015 2:52 pm
Yeray,
Yeah, that's neat! Thanks very much!
Toreba
