Axis label position
toreba
Axis label position
Post by toreba » Thu Aug 06, 2015 3:26 pm
I'm looking for guidance as to how this property works when set through the chart editor. If I select 'at tick' all is well. If I select 'before tick' or 'after tick', the label is displaced 1.5 ticks in the respective direction. It moves too far. It is 'before' or 'after' the wrong tick. The option 'center' seems to do the same as 'before tick' and puts the label in completely the wrong place. Is this a bug?
Thanks for any advice!
Toreba
Re: Axis label position
Post by Narcís » Fri Aug 07, 2015 7:33 am
Hi Toreba,
This might depend on the axis increment and the number of labels. Can you please attach a simple example project we can run "as-is" to reprodcue the problem here?
toreba
Post by toreba » Fri Aug 14, 2015 3:19 pm
Narcis,
I have uploaded a very simple example project as 'DateTimeAxisLabelProject.zip' with some screen shots showing how it looks for me using TeeChart Pro 2013.09.131119 32bit VCL in Delphi XE5.
The problems are apparent at design time. No need to run it.
With bottom axis labels positioned 'at tick' all is well.
Positioned 'before tick' the label appears just after the preceding tick, which looks wrong
Positioned 'after tick' the label appears just before the following tick, which also looks wrong
Positioned at 'center' dos the same as 'before tick'.
Hope that's clear.
Toreba
Post by Yeray » Tue Aug 18, 2015 9:13 am
Hi Toreba,
You are right, there are a couple of things to improve here.
I've added a ticket to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1273
Feel free to add your mail to the CC list of the ticket to be automatically notified when an update arrives.
toreba
Post by toreba » Wed Aug 19, 2015 3:01 pm
Yeray,
Thanks for the confirmation.
I don't think I have rights to edit the cc list on the ticket though...
Toreba
Post by Yeray » Wed Aug 19, 2015 3:36 pm
Hi Toreba,
You will see the option "Add me to the CC list" when logged into the system
You can register here.
