Drilldown in a CrossTab series.
MVBobj
Post by MVBobj » Tue Aug 25, 2015 7:46 pm
Here's a problem I'm not sure how to solve.
I have a DBChart. Series Data Source is set to CrossTab and the Dataset is a SQL query with 3 data fields: Sales (double), Location (string) and AsOfDate (date).
Calc: sum of Sales
Group by: Location
Labels: AsOfDate
There are 6 locations and some locations may not have sales for all dates.
If I click on a series segment to drilldown to view underlying data for that Location/AsOfDate, how do I find the specific record in the series' parent Dataset? While it's true I have the YValue for that series segment, and I have the Location because I know which subseries was clicked, but I don't have the actual date of the XValue. I have the XLabel - but potential formatting issues could confuse things enough to make that option undesirable. I have the ValueIndex, but that isn't reliable either - there are 6 groups and there may be data gaps due to no sales activity on some dates. I need a minimum of 2 pieces of information here: the Location and the AsOfDate.
An end-user clicks on a series segment to see additional information about that segment. How do I find that information?
Re: Drilldown in a CrossTab series.
Post by Yeray » Fri Aug 28, 2015 10:17 am
The new "Series Detail" feature could help you with this.
Take a look at the following two examples.
- SeriesDetailSample is a simple example showing how to use this "Series Detail" new feature.
- CrossTabSeriesDetailSample is an example using the "Series Detail" new feature in combination with TDBCrossTabSource.
This new feature will be available with the next maintenance release.
