MasterAxis
franckgar
MasterAxis
Post by franckgar » Wed Nov 24, 2004 10:19 am
Hello!
I assigned the propertie MasterAxis of an axis to an axis of another chart, but when I zoomed the master axis I didn't see modifications applied to other axes. Did someone test this functionality successfully ?
thanks
franckgar
Post by Pep » Thu Nov 25, 2004 2:52 pm
basically all you must do is read (all) first chart axes minimum and maximum value and then use these values to set second chart axes minimum/maximum value (asigning the values in the SetMinMax method).
Chart2.Axes.Bottom.SetMinMax(Chart1.Axes.Bottom.Minimum,Chart1.Axes.Bottom.Maximum);
Chart2.Axes.Left.SetMinMax(Chart1.Axes.Left.Minimum,Chart1.Axes.Left.Maximum);
For both charts and also in the OnUndoZoom event.
