Something like Chart1[n].XValues.DateTime for ZValues?
Jan
Post by Jan » Wed Nov 24, 2004 3:31 pm
I'm sure you have been asked several times, but i can't find the answer at the moment. I would like to use a timescale on different axis in a 3D TPoint3DSeries. This has do be done by code at runtime. Im am using the following code for the x-Values:
SeriesCounter := Chart1.SeriesCount; // get series No. before
CHart1.AddSeries (TPoint3DSeries); // generating the new series
With (Chart1.Series[SeriesCounter] as TPoint3DSeries) do // so we dont have to sub one
Begin
Clear;
VertAxis := aLeftAxis;
HorizAxis := aBottomAxis;
Zorder := 0;
ColMin := Infinity;
ColMax := NegInfinity;
Visible := frm3dSurface.cb3dPlotVisible.Checked;
LinePen.Visible := frm3dSurface.cb3dPlotLinePoints.Checked;
Title := frm3dSurface.ed3dSurfScatterName.Text;
If frm3DSurface.cob3dXFormat.ItemIndex <> 0 THen Chart1[Chart1.SeriesCount-1].XValues.DateTime := True
Else Chart1[Chart1.SeriesCount-1].XValues.DateTime := False;
// If frm3DSurface.cob3dZFormat.ItemIndex <> 0 THen Chart1[Chart1.SeriesCount-1].ZValues.DateTime := True
// Else Chart1[Chart1.SeriesCount-1].ZValue.DateTime := False;
If frm3DSurface.cob3dYFormat.ItemIndex <> 0 THen Chart1[Chart1.SeriesCount-1].YValues.DateTime := True
Else Chart1[Chart1.SeriesCount-1].YValues.DateTime := False;
What can i write for the two lines, where i try to set the format for the ZValues? I don't know what to use... Or any other ideas how to improve this code?
Thanks, Jan
Post by Pep » Thu Nov 25, 2004 2:34 pm
Hi Jan,
how about using :
(Chart1[0] as TPoint3DSeries).ZValues.DateTime := true;
Jan
Post by Jan » Mon Nov 29, 2004 11:37 am
I just checked the history of the last steps... It was my fault. The first try was without as TPoint3DSeries and with Zvalues , the second with as TPoint3DSeries but with Zvalue (without the last 's') and that caused an error I obviously did not read fully...
Now it is working, thanks!
Jan
