Axis Disappearing When Grid Lines Not Behind
Tony Jackson
Post by Tony Jackson » Fri Oct 09, 2015 3:07 pm
When I set for example Chart.Axis.Behind := False (or Chart.AxisBehind := False) it brings the grid lines forward which is what I want.
The problem is that all 4 axis including the axis border, labels and scale disappear. I had to set the chart walls to true to get the chart boundary to not look ridiculous. See images. We are using the charts in a complicated way. Many series - some polygons, circles, lines, etc.
I know it works because I can do it in a simple program with one series.
I am using the pro version.
Re: Axis Disappearing When Grid Lines Not Behind
Post by Narcís » Wed Oct 14, 2015 9:14 am
Hi Tony,
If it works fine with a simpler example, which I confirmed here, you should try to isolate the part of your code that interferes with that. Alternatively, it would be helpful if you arranged a simple example project we can run "as-is" to reproduce the problem here.
