we have another odd problem that wasn't there in our old Version of TChart.
In our Module there are multiple Chartobjects. The code to fIll the values and configure the charts is the same for all charts. We take the first chart object with it's series definitions and clone it onto the other charts, then fill the values. With this method we only need to configure the first chart (the one on the left) in the IDE and all properties are copied to the other charts automatically. Because of this every chart *should* look the same (!) and it did in the old version of TChart. In the new version, as you can see, the position of the marks is only correct in the first chart. The marks are set to Auto Position in the first chart. I tried setting Auto Position do true and false in the code in all charts without any effect. I can't figure out where the Problem is. Do you have any clues or ideas?
Marks distance when cloning a chart
- 1.png (26.71 KiB) Viewed 4031 times
Re: Marks distance when cloning a chart
This thread comes from here. I've split your post to a new thread because it asks an unrelated issue.
How are you cloning the chart? Can you please attach a simple example we can use as-is to reproduce the problem here?
