TeeExport
jpm
TeeExport
Post by jpm » Tue Dec 01, 2015 5:57 pm
When I try to save the raw data in text format using the TeeExport dialog box (slide 1) I quite often get an error reporting "not enough memory..." (slide 2). This situation mainly occurs for large series ( over 100'000 points).
It's stange: I save all the x-y couples for each series "by myself" with a very easy procedure and I don't notice that it was necessary to allocate memory for this action: with llops over series and number of points I never met any problems. Maybe you store the list in a listbox wich can be huge in some situations(?)
Could you tell me where the problem is comming from and how can I avoid it.
Thank you in advance for your answer.
JPM
jpm
Re: TeeExport
Post by jpm » Tue Dec 01, 2015 6:16 pm
for information, I call the dialog box with th following procedure:
procedure Exporter(var T ; var C : TChart);
var df, af : string;
   getdir(0,df);
   if Go_to_Current_Scratch() then
      getdir(0,af);
      TeeExport(TForm(T),C); // ,af);
   chdir(df);
Re: TeeExport
Post by Yeray » Wed Dec 02, 2015 11:16 am
Are you pressing "Save..." or "Preview..."? If the later, the problem could be in notepad.
