Direct Access to Color Grid Values
ix07
Post by ix07 » Mon Jan 04, 2016 7:08 pm
Hi.
We are trying to optimize the performance of TColorGrid and are wondering about the usage of the "Values" property. Internally it always seems to call AddXYZ - regardless if the value already existed.
Is there no way to only update the color values of a grid?
Example:
const double xStepWidth = 1.0, yStepWidth = 1.0;
double yCurrent = 0.0;
for(unsigned y = 0; y < data_.size(); ++y)
   double xCurrent = 0.0;
   for(unsigned x = 0; x < data_[y].size(); ++x)
      if(update)
         series->Value[xCurrent][yCurrent] = data_[y][x];
         series->AddXYZ(xCurrent, data_[y][x], yCurrent);
      xCurrent += xStepWidth;
   yCurrent += yStepWidth;
If the flag "update" is true internally AddXYZ still is called.
Re: Direct Access to Color Grid Values
Post by Yeray » Tue Jan 05, 2016 12:35 pm
Look at the TCustom3DGridSeries.SetValue procedure:
procedure TCustom3DGridSeries.SetValue(X, Z: Integer;
  const Value: TChartValue);
var tmp : Integer;
  if IDirtyGrid then
     AddXYZ(x,Value,z)
    tmp:=GridIndex[x,z];
    if tmp<>-1 then YValues.Value[tmp]:=Value
               else GridIndex[x,z]:=AddXYZ(x,Value,z);
It calls AddXYZ when it doesn't find a value at the given [X, Z] point.
Note GridIndex may not have index 0 populated; so the way to manipulate it would be:
var i, tmpMinX, tmpMinZ: Integer;
  tmpMinX:=Round(Series1.XValues.MinValue)-1;
  tmpMinZ:=Round(Series1.ZValues.MinValue)-1;
  for i:=0 to Series1.Count-1 do
    Series1.Value[ Round(Series1.XValues.Value[i])-tmpMinX,
                   Round(Series1.ZValues.Value[i])-tmpMinZ]:=random*1.5-0.5;
ix07 wrote:Is there no way to only update the color values of a grid?
If you want use the ColorRange feature, so to change the colors manipulating the YValues, you can call this after manipulating the Value array as in the snipped above to force the series to be redrawn:
  Series1.RefreshSeries;
  Series1.Repaint;
To directly assign a color in a series point, in general you should set the ValueColor array. Ie:
    Series1.ValueColor[i]:=RGB(round(random*255), round(random*255), round(random*255));
