Zooming from Outside Chart axes
X-Ray
Post by X-Ray » Mon Jan 18, 2016 11:25 am
often when a range that needs to be zoomed in is close to an axis its not easy to achieve because the zoom rectangle can
only be started inside the chart axes area. Is there a simple option to enable the zoom rectangle to start outside the TChart axes ?
best regards,
X-ray
Re: Zooming from Outside Chart axes
Post by Yeray » Mon Jan 18, 2016 3:10 pm
You can Activate the Zoom and Panning at the OnClickBackground event as follows:
procedure TForm1.Chart1ClickBackground(Sender: TCustomChart;
  Button: TMouseButton; Shift: TShiftState; X, Y: Integer);
  with Chart1 do
    if Zoom.Allow and (Button=Zoom.MouseButton) and
       (Zoom.KeyShift<=Shift) then
    Begin
      if Zoom.Direction=tzdVertical then x:=ChartRect.Left;
      if Zoom.Direction=tzdHorizontal then y:=ChartRect.Top;
      Zoom.Activate({$IFDEF FMX}Round{$ENDIF}(x),{$IFDEF FMX}Round{$ENDIF}(y));
         Zoom.X1:={$IFDEF FMX}Round{$ENDIF}(ChartRect.Right);
         Zoom.Y1:={$IFDEF FMX}Round{$ENDIF}(ChartRect.Bottom);
    if (AllowPanning<>pmNone) and (Button=ScrollMouseButton) and
       (TeeScrollKeyShift<=Shift ) then
    Begin
      Panning.Activate({$IFDEF FMX}Round{$ENDIF}(x),
    CancelMouse:=false;
X-Ray
Post by X-Ray » Tue Jan 19, 2016 7:02 am
Hello Yeray,
very useful, thank You !
In fact it would be nice if this was just another flag/option of TChart.
best regards,
X-Ray
Post by Yeray » Tue Jan 19, 2016 9:47 am
Ok. I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1408
