Drawing lines on a tColorGridSeries
dave
Post by dave » Tue May 10, 2016 7:50 pm
The idea here is to draw a polygon on my image with Polyline. So, while holding the CTRL key
down, click points on the chart. A line should be drawn between points and stretch between
the last point clicked and the mouse.
To close the polygon, release the CTRL key and click the final point.
This also stops the drawing.
In the Mouse move event, the old "polyline" should be XOR'd off the chart and the new line
drawn, giving the rubber band effect. The XOR is not happening. Why?
Also, once the final polygon is drawn, if you move the mouse the image refreahes deleting the
polygon. If I turn off AutoRepaint, the old lines are never removed.
How do I get the polygon to stay on the image? Can you make any suggestions?
I tried to attach a small application to demonstrate. Did you get it? I don't see it...have my upload permissions changed? I can resend the files if you allow me to.
Here is the application text
unit Unit1;
interface
uses
  Vcl.Controls, Vcl.Forms, Vcl.Dialogs, VclTee.TeeGDIPlus, Vcl.StdCtrls,
  VCLTee.TeEngine, VCLTee.TeeProcs, VCLTee.Chart, Vcl.ExtCtrls,
  VCLTee.TeeSurfa, VCLTee.TeeEdit;
type
  TForm1 = class(TForm)
    Chart1: TChart;
    Panel1: TPanel;
    Memo1: TMemo;
    procedure Chart1MouseDown(Sender: TObject; Button: TMouseButton;
    procedure Chart1MouseMove(Sender: TObject; Shift: TShiftState; X,
      Y: Integer);
  private
    { Private declarations }
    PTarray : array of TPoint;
    Drawing : boolean;
  public
    { Public declarations }
const
  pmode : TPenMode = pmNot;
var
  Form1: TForm1;
implementation
{$R *.dfm}
   if (ssCtrl in Shift) then
       // Check if we are starting to draw a new polygon
       if Length(PTarray) <= 0  then
           // Initialize the array to hold the polygon vertex list.
           // Allocate an extra element to hold the curent mouse position
           // and use it for the last/next vertex.
           SetLength(PTarray, 1);
           PTarray[0].X := X;
           PTarray[0].Y := Y;
           Drawing := True;
         end
       else if Length(PTarray) > 1 then
           // Clear the old line we were stretching to the last vertex
           Chart1.Canvas.Pen.Width := 0;
           Chart1.Canvas.Pen.Color := clWhite;
           Chart1.Canvas.Brush.Style := bsClear;
           //Chart1.Canvas.Pen.Mode := pmXor;
           //Chart1.Canvas.Pen.Mode := pmode;
           Chart1.Canvas.Pen.Mode := pmNotCopy;
           Chart1.Canvas.Polyline(PTarray);
           Chart1.Repaint;
           Application.ProcessMessages;
       // Increase the array to hold the new vertex.
       SetLength(PTarray, Length(PTarray)+1);
       // Save the new vertex
       PTarray[High(PTarray)].X := X;
       PTarray[High(PTarray)].Y := Y;
       // Draw a line from the previous vertex to this new one
       Chart1.Canvas.Pen.Width := 1;
       Chart1.Repaint;
     end
       // Close the polygon;
       PTarray[High(PTarray)] := PTarray[0];
       Chart1.Repaint;
       Drawing := False;
       SetLength(PTarray, 0);
  Y: Integer);
  // Check if we are drawing the polygon
  if Drawing then
      // Remove the old line
      // Save new point
      // Draw the new line
      Chart1.Repaint;
    end
  chart1.AddSeries(TColorGridSeries).FillSampleValues();
  chart1.AutoRepaint := True;
end.
Re: Drawing lines on a tColorGridSeries
Post by Yeray » Thu May 12, 2016 9:37 am
Since you have the TeeChart sources, you can take a look at how the TCursorTool draws the lines with XOR techniques.
An alternative would be to maintain the arrays of points at the OnMouseDown&OnMouseMove events and to draw them at OnAfterDraw.
dave
Post by dave » Thu May 12, 2016 12:03 pm
Thanks Yeray,
Can you direct my into the source code file(s) to look at. The way the cursor works is preferable I think. Otherwise I can put them in the OnAfterDraw event as you say.
Post by Yeray » Thu May 12, 2016 3:04 pm
dave wrote:Can you direct my into the source code file(s) to look at. The way the cursor works is preferable I think.
Take a look at the TCursorTool.ChartMouseEvent and TCursorTool.RedrawCursor methods in TeeTools.pas.
dave
Post by dave » Thu May 12, 2016 3:26 pm
Thanks!
